Help & Support Navigation
- Mark as Read
- Plusnet Blogs
- Help & Support Navigation
12-04-2007
7:01 PM
The Problem The Help & Support page is both a section index and a section in its own right. Therefore where should it appear in the tabbed navigation? Thanks to bradley8131 for raising this issue in the forums. The (possible) Solution(s)
- Don't change anything and let users work out that they need to click on the 'Help & Support' tab to get back to the help index.
- Add a 'Help & Support' as a section alongside 'Service Status', 'Help Assistant' and 'My Questions'
- Add an image link to the help pages index in the right column similar to the current link to 'Help Assistant'
- Create a new Help & Support section index that links off to each of the sub sections (of which the current help pages index would be a new one).
