Connection issues
colinbdunkley
Re: Connection issues
I'll try the other router tomorrow and if i get the same results then I know its outside my property. If its fixed then i know its my router i guess. Its the only thing I haven't tried
Fixes: 583
What lights are showing on the ONT ? and do they change when you have problems?
nitram
For reference, my ping to a PN hub 2 is 1ms
nitram
Take your router to Mom's and see if problem moves with it, then bring Mom's to yours to check.
How old is your router?
Browni
Aspiring Hero
Fixes: 61
I would expect <1ms for an ethernet connection like below...
PS C:\Windows\System32> ping 192.168.1.254
Pinging 192.168.1.254 with 32 bytes of data:
Reply from 192.168.1.254: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.1.254:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
nitram
My 1ms is wireless
colinbdunkley
Hi folks, no the lights don't change on the ONS box. I dont lose connection, its just really bad. I used a more extensive network checker and the latency goes right up while downloading and uploading and the line jitter is around 30ms. I had around 0.8% packet loss. I have network graphs on the ps5 while playing online and it will be fine for about 15 seconds, i get a latency spike and packet loss then its ok again for another 15 seconds then repeat. My Son has the same problem playing on his Oculus
colinbdunkley
colinbdunkley
I haven't got a laptop to check so I used an app but it looks much higher now, I'm confused
colinbdunkley
Yeah im pinging my router through an app and I'm getting mixed results ranging from 3ms upto 175ms. Does this mean its my router thats at fault?
nitram
Looks likely,
Dodgy power supplies can give weird results, include these in your testing with Mom's
nitram
Are you pinging wired or wireless?
colinbdunkley
Hi, wireless. I haven't got a laptop to check wired. Im using a network diagnostic tool on my pad and pinging 192.168.1.254. Ive had this router about 4 months
colinbdunkley
Oh really? So the adapter powering the router could be playing a factor?
nitram
Waiting to see results of router swaps tomorrow is best way forward, then either chase PN for a replacement router FOC or  get them to sort out network problem
