Full Fibre Hub
MattDeakin
Full Fibre Hub
Hi, I've just upgraded to the Full Fibre 300. I think I need a new hub, Hub Two, with it but haven't had any confrimation that I will be sent one. Thanks
7 REPLIES 7
bill888
Champion
Fixes: 40
Re: Full Fibre Hub
Phone Customer Options Team on 0800 013 2632 to arrange a free Hub 2 to be sent to you.  It will cost £9.99 delivery.
Fixes: 585
Re: Full Fibre Hub
@MattDeakin what Hub do you currently have ? If its a Hub one then it will work, although the upstream will be limited to around 30Mb. Just connect the WAN port to the ONT with a cat5e (or better) ethernet cable
MattDeakin
Re: Full Fibre Hub
Thanks for the replys, good to know the Hub One will mostly work. I might do what @bill888 said though and order the new one still. Been having dropouts with the previous non fibre pack so hopefully it'll help as well as having fibre. Thanks Smiley
Fixes: 585
Re: Full Fibre Hub
@MattDeakin yes, I'd suggest ordering the Hub2 anyway. Its a better router than the Hub1, although it only has 3 LAN ports. The 4th port is a dedicated WAN port.
MattDeakin
Re: Full Fibre Hub
Just ordered it. They said the Hub1 will only do about 80Mbps down as well so kind of had to get it ordered. Thanks again for the help Smiley
Fixes: 585
Re: Full Fibre Hub
I believe they're wrong, we had it confirmed on here by the product owner that the restriction on the Hub one is upstream only
MattDeakin
Re: Full Fibre Hub
Ahh right, I did think that it was a little low. Thanks for the info!
