Odd TBB test ?
- Odd TBB test ?
Re: Odd TBB test ?
15-05-2017 6:42 PM
Yeah I guessed as much, I've posted over at your other thread.
Re: Odd TBB test ?
15-05-2017 6:50 PM
Did you run the Download test and get 7mb/s ?
iperf3 -c bouygues.testdebit.info -p 5200 -R
Re: Odd TBB test ?
15-05-2017 6:53 PM
I dont really understand these tests.
I see the slow single TBB tests and same on samknows, but speedtest.net are OK?
Connecting to host bouygues.testdebit.info, port 5200
Reverse mode, remote host bouygues.testdebit.info is sending
[ 4] local 192.168.1.104 port 61134 connected to 89.84.127.53 port 5200
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 4.05 MBytes 34.0 Mbits/sec
[ 4] 1.00-2.00 sec 1.11 MBytes 9.36 Mbits/sec
[ 4] 2.00-3.00 sec 1.47 MBytes 12.3 Mbits/sec
[ 4] 3.00-4.00 sec 949 KBytes 7.77 Mbits/sec
[ 4] 4.00-5.00 sec 1.08 MBytes 9.04 Mbits/sec
[ 4] 5.00-6.00 sec 1.27 MBytes 10.7 Mbits/sec
[ 4] 6.00-7.00 sec 1.08 MBytes 9.05 Mbits/sec
[ 4] 7.00-8.00 sec 1012 KBytes 8.29 Mbits/sec
[ 4] 8.00-9.00 sec 1.35 MBytes 11.3 Mbits/sec
[ 4] 9.00-10.00 sec 1.65 MBytes 13.8 Mbits/sec
[ ID] Interval Transfer Bandwidth Retr
[ 4] 0.00-10.00 sec 16.6 MBytes 14.0 Mbits/sec 26 sender
[ 4] 0.00-10.00 sec 15.1 MBytes 12.7 Mbits/sec receiver
iperf Done.
Re: Odd TBB test ?
15-05-2017 6:57 PM
Very odd, I'll take that back then.
@Kelly Another strange one for you!
Re: Odd TBB test ?
15-05-2017 7:02 PM
My bad, I thought the Samknows tests were Multithread not single.
The test your doing above Is Single threaded.
Re: Odd TBB test ?
15-05-2017 7:27 PM
OK, no worries, Ive opened a ticket with PN and given the details of the speedtests etc.
Hopefully they wont try to send an engineer because this is obviously a fault within the network somewhere.
Ticket #149768949
Is anyone at PN monitoring this thread?
Re: Odd TBB test ?
15-05-2017 7:57 PM
@philcecchini I would say @Kelly Will have a mooch sometime this week.
Just keep pushing back with "It's a Single Thread problem"
And no you don't need anybody round either.
Re: Odd TBB test ?
16-05-2017 9:14 AM
@philcecchini: Are you noticing performance problems? What are you seeing?
Does anyone know any details about http://bouygues.testdebit.info? Are they a good place to use as a test. I.e. is the infrastructure supporting it going to be fine for significant numbers of tests? (Bear in mind it's in located in France, so not immediately local to the UK networks)
Ex-Broadband Service Manager
Re: Odd TBB test ?
16-05-2017 9:22 AM
It's solid from here.
iperf3 -c bouygues.testdebit.info -p 5200 -R Connecting to host bouygues.testdebit.info, port 5200 Reverse mode, remote host bouygues.testdebit.info is sending [ 4] local 192.168.0.14 port 53770 connected to 89.84.127.53 port 5200 [ ID] Interval Transfer Bandwidth [ 4] 0.00-1.00 sec 3.63 MBytes 30.4 Mbits/sec [ 4] 1.00-2.00 sec 3.99 MBytes 33.4 Mbits/sec [ 4] 2.00-3.00 sec 3.99 MBytes 33.5 Mbits/sec [ 4] 3.00-4.00 sec 3.99 MBytes 33.5 Mbits/sec [ 4] 4.00-5.00 sec 3.99 MBytes 33.5 Mbits/sec [ 4] 5.00-6.00 sec 3.99 MBytes 33.5 Mbits/sec [ 4] 6.00-7.00 sec 3.99 MBytes 33.5 Mbits/sec [ 4] 7.00-8.00 sec 3.99 MBytes 33.5 Mbits/sec [ 4] 8.00-9.00 sec 3.99 MBytes 33.5 Mbits/sec [ 4] 9.00-10.00 sec 3.99 MBytes 33.5 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 40.8 MBytes 34.3 Mbits/sec 11 sender [ 4] 0.00-10.00 sec 39.7 MBytes 33.3 Mbits/sec receiver iperf Done.
The OP has a thread with tests here
Re: Odd TBB test ?
16-05-2017 10:01 AM
Sluggish performance and timeouts intermittently, I'm on Samknows so I saw the degradation on there.
Seems to have started on April 19ish.
Re: Odd TBB test ?
16-05-2017 10:02 AM
Latest Test
C:\Users\Phil\Desktop\iperf-3.1.3-win64>iperf3 -c bouygues.testdebit.info -p 5200 -R
[ 4] local 192.168.1.104 port 57791 connected to 89.84.127.53 port 5200
[ 4] 0.00-1.00 sec 2.49 MBytes 20.9 Mbits/sec
[ 4] 1.00-2.00 sec 1.01 MBytes 8.47 Mbits/sec
[ 4] 2.00-3.00 sec 686 KBytes 5.63 Mbits/sec
[ 4] 3.00-4.00 sec 1.01 MBytes 8.45 Mbits/sec
[ 4] 4.00-5.00 sec 1.25 MBytes 10.5 Mbits/sec
[ 4] 5.00-6.00 sec 1010 KBytes 8.27 Mbits/sec
[ 4] 6.00-7.00 sec 1.26 MBytes 10.6 Mbits/sec
[ 4] 7.00-8.00 sec 1.59 MBytes 13.4 Mbits/sec
[ 4] 8.00-9.00 sec 1.02 MBytes 8.54 Mbits/sec
[ 4] 9.00-10.00 sec 1.22 MBytes 10.2 Mbits/sec
[ 4] 0.00-10.00 sec 13.4 MBytes 11.2 Mbits/sec 29 sender
[ 4] 0.00-10.00 sec 12.6 MBytes 10.6 Mbits/sec receiver
iperf Done.
Re: Odd TBB test ?
16-05-2017 11:28 AM
Definitely go down the faults route while we look as well.
Re: Odd TBB test ?
16-05-2017 11:37 AM
Ticket is awaiting response from faults team.
Thanks for your time.
Re: Odd TBB test ?
16-05-2017 5:04 PM - edited 16-05-2017 5:08 PM
As expected faults have thrown it back saying nothing wrong, I think this is beyond the team there as there is no fault with the line, its a problem within your network?
Can you please escalate this?
Iperf
[ 4] local 192.168.1.104 port 62863 connected to 89.84.127.53 port 5200
[ 4] 0.00-1.01 sec 1.00 MBytes 8.33 Mbits/sec
[ 4] 1.01-2.01 sec 1.50 MBytes 12.6 Mbits/sec
[ 4] 2.01-3.01 sec 768 KBytes 6.29 Mbits/sec
[ 4] 3.01-4.01 sec 1.12 MBytes 9.40 Mbits/sec
[ 4] 4.01-5.00 sec 2.00 MBytes 17.0 Mbits/sec
[ 4] 5.00-6.00 sec 2.25 MBytes 18.8 Mbits/sec
[ 4] 6.00-7.00 sec 1.75 MBytes 14.7 Mbits/sec
[ 4] 7.00-8.01 sec 2.12 MBytes 17.7 Mbits/sec
[ 4] 8.01-9.01 sec 2.12 MBytes 17.8 Mbits/sec
[ 4] 9.01-10.01 sec 2.12 MBytes 17.7 Mbits/sec
[ 4] 0.00-10.01 sec 16.8 MBytes 14.0 Mbits/sec sender
[ 4] 0.00-10.01 sec 16.6 MBytes 13.9 Mbits/sec receiver
iperf Done.
[ 4] local 192.168.1.104 port 62866 connected to 89.84.127.53 port 5200
[ 4] 0.00-1.01 sec 678 KBytes 5.52 Mbits/sec
[ 4] 1.01-2.00 sec 712 KBytes 5.86 Mbits/sec
[ 4] 2.00-3.01 sec 508 KBytes 4.13 Mbits/sec
[ 4] 3.01-4.00 sec 596 KBytes 4.90 Mbits/sec
[ 4] 4.00-5.00 sec 542 KBytes 4.44 Mbits/sec
[ 4] 5.00-6.01 sec 993 KBytes 8.06 Mbits/sec
[ 4] 6.01-7.01 sec 997 KBytes 8.20 Mbits/sec
[ 4] 7.01-8.00 sec 778 KBytes 6.43 Mbits/sec
[ 4] 8.00-9.00 sec 1.16 MBytes 9.72 Mbits/sec
[ 4] 9.00-10.00 sec 1.06 MBytes 8.88 Mbits/sec
[ 4] 0.00-10.00 sec 8.15 MBytes 6.84 Mbits/sec 26 sender
[ 4] 0.00-10.00 sec 8.01 MBytes 6.72 Mbits/sec receiver
iperf Done.
Re: Odd TBB test ?
16-05-2017 5:08 PM
Hi, I'm sorry to hear this, our Faults team will have ran several checks before advising you of this however you can still raise a fault yourself Here - Tony
