Odd TBB test ?
- Odd TBB test ?
Re: Odd TBB test ?
16-05-2017 5:10 PM
Thanks Tony,
But the tests they have run are testing the line, the problem isnt there.
Ive updated the ticket and asked for it to be escalated.
Hopefully one of the guys will pick it up.
Re: Odd TBB test ?
16-05-2017 5:27 PM
I can see a problem with Single thread on your TBB test with Multithread less impacted.
I spent many hours testing all my network with various bits of kit only to be told, we can't do anything... then out of the blue my problems disolved into thin air. @Kelly Came to the conclusion it was out of plusnets control (Openreach) more likely then, so I guess it's a waiting game.
@philcecchini Just out of intrest..
What speed do you get on the down if you limit the speed like so iperf3 -c bouygues.testdebit.info -p 5200 -b 30M -R
Also, is streaming impacted ? (this was a big factor with me) mostly evenings though!
Re: Odd TBB test ?
16-05-2017 6:34 PM
Kelly has been helping with some testing , we had removed my static IP , same results now I have the Pro add on to see if any difference or to point where the problem lies but no avail as yet
Re: Odd TBB test ?
16-05-2017 7:06 PM
@rongtw I was under the impression you was ok since I last asked you, sorry to hear your still having issues.
Can't plusnet get you 2 to run an iperf3 server so they can test Single thread problems directly with you, they can at least say yep we see it ?
As far as Samknows goes, they test both single and multithread, So I assume thats an average of both tests.
I guess it's hard for Plusnet if they can't see the complete picture all the way through the network.
I can see @philcecchini was asked to capture some packets with wireshark, did they ask you rongtw ?
Re: Odd TBB test ?
16-05-2017 7:24 PM
Like you say its going to be hard to pin point the problem in BT network
Re: Odd TBB test ?
16-05-2017 7:28 PM
I found a way to get around it - moved to EE, seems fine there so far.
Re: Odd TBB test ?
16-05-2017 8:54 PM
Not many good things about EE, mainly negative reviews. Im coming to the end of my contract, and been offered an attractive deal to stay, but if this is not sorted then I will have to seriously consider moving.
Re: Odd TBB test ?
16-05-2017 8:56 PM - edited 16-05-2017 8:59 PM
@30FTTC06 looks the same as he normal test here?
I dont really understand what they want from Wireshark?
Its really random what happens, sometimes streaming is fine, and othertimes youtube and iplayer stutter.
I have SkyQ and again not really impacted, but I dont watch online stuff that much, mainly the kids that use on demand stuff.
Ive had issues with failed webpages and slow loading of pages, I didnt really suspect anything until I saw the speeds on Samknows dropping.
Ive also lost the usage monitoring again on my account, so something is obviously going on.
Connecting to host bouygues.testdebit.info, port 5200
Reverse mode, remote host bouygues.testdebit.info is sending
[ 4] local 192.168.1.104 port 63860 connected to 89.84.127.53 port 5200
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 2.19 MBytes 18.3 Mbits/sec
[ 4] 1.00-2.00 sec 917 KBytes 7.54 Mbits/sec
[ 4] 2.00-3.01 sec 770 KBytes 6.28 Mbits/sec
[ 4] 3.01-4.00 sec 1.12 MBytes 9.50 Mbits/sec
[ 4] 4.00-5.01 sec 883 KBytes 7.14 Mbits/sec
[ 4] 5.01-6.00 sec 516 KBytes 4.28 Mbits/sec
[ 4] 6.00-7.00 sec 753 KBytes 6.17 Mbits/sec
[ 4] 7.00-8.00 sec 760 KBytes 6.23 Mbits/sec
[ 4] 8.00-9.00 sec 613 KBytes 5.01 Mbits/sec
[ 4] 9.00-10.01 sec 678 KBytes 5.49 Mbits/sec
[ ID] Interval Transfer Bandwidth Retr
[ 4] 0.00-10.01 sec 9.59 MBytes 8.03 Mbits/sec 39 sender
[ 4] 0.00-10.01 sec 9.19 MBytes 7.70 Mbits/sec receiver
iperf Done.
Re: Odd TBB test ?
16-05-2017 11:00 PM
Yeah the test is the same as the others and of course your HTML5 speedtest below
As for a Wireshark capture... they are prolly looking at various things like traffic they send/recieve VS what you recieve/send, and indeed what class/que type and more. But no it wont show why your getting loss.
What router/modem you using?
Usage monitoring is broke for me most of the time so I wouldn't take any notice of that.
Re: Odd TBB test ?
17-05-2017 10:30 AM
Things seem better this morning?
Has anything been done on the network side?
iperf3 -c bouygues.testdebit.info -p 5200 -R
[ 4] local 192.168.1.104 port 49669 connected to 89.84.127.53 port 5200
[ 4] 0.00-1.00 sec 6.51 MBytes 54.6 Mbits/sec
[ 4] 1.00-2.00 sec 6.96 MBytes 58.4 Mbits/sec
[ 4] 2.00-3.00 sec 7.02 MBytes 58.9 Mbits/sec
[ 4] 3.00-4.00 sec 7.00 MBytes 58.7 Mbits/sec
[ 4] 4.00-5.00 sec 6.95 MBytes 58.3 Mbits/sec
[ 4] 5.00-6.00 sec 6.95 MBytes 58.3 Mbits/sec
[ 4] 6.00-7.00 sec 6.95 MBytes 58.3 Mbits/sec
[ 4] 7.00-8.00 sec 6.97 MBytes 58.5 Mbits/sec
[ 4] 8.00-9.00 sec 6.94 MBytes 58.2 Mbits/sec
[ 4] 9.00-10.00 sec 6.95 MBytes 58.3 Mbits/sec
[ 4] 0.00-10.00 sec 70.6 MBytes 59.2 Mbits/sec 216 sender
[ 4] 0.00-10.00 sec 69.5 MBytes 58.3 Mbits/sec receiver
iperf Done.
Re: Odd TBB test ?
18-05-2017 9:54 AM - edited 18-05-2017 9:55 AM
No change that I'm aware of (but I'm due a sit down in 5 minutes with the Network team so I'll ask)
Usage reporting isn't connected to anything of this, so don't worry about that.
People using iperf: is there another test site we can use to compare against? (Just to make sure you're not seeing a saturated link somewhere to that French test site)
Ex-Broadband Service Manager
Re: Odd TBB test ?
18-05-2017 10:48 AM
@Kelly Latest test, something has clearly settled down?
The iperf servers wont let more than 1 test run concurrently, so these tests should be reliable, just the international connectivity to consider. I also used a different server in Holland to compare.
Looking at the samknows tests something clearly changed yesterday morning?
iperf3 -c speedtest.serverius.net -p 5002 -R
Connecting to host speedtest.serverius.net, port 5002
Reverse mode, remote host speedtest.serverius.net is sending
[ 4] local 192.168.1.104 port 56718 connected to 178.21.16.76 port 5002
[ 4] 0.00-1.00 sec 5.62 MBytes 47.0 Mbits/sec
[ 4] 1.00-2.00 sec 6.70 MBytes 56.3 Mbits/sec
[ 4] 2.00-3.00 sec 6.03 MBytes 50.6 Mbits/sec
[ 4] 3.00-4.00 sec 6.47 MBytes 54.3 Mbits/sec
[ 4] 4.00-5.01 sec 6.27 MBytes 52.1 Mbits/sec
[ 4] 5.01-6.01 sec 6.50 MBytes 54.4 Mbits/sec
[ 4] 6.01-7.00 sec 6.77 MBytes 57.3 Mbits/sec
[ 4] 7.00-8.00 sec 6.46 MBytes 54.2 Mbits/sec
[ 4] 8.00-9.00 sec 6.82 MBytes 57.2 Mbits/sec
[ 4] 9.00-10.01 sec 6.62 MBytes 54.8 Mbits/sec
[ 4] 0.00-10.01 sec 65.0 MBytes 54.5 Mbits/sec 0 sender
[ 4] 0.00-10.01 sec 64.5 MBytes 54.0 Mbits/sec receiver
iperf Done.
Re: Odd TBB test ?
18-05-2017 10:59 AM
The graph in post #608 and the iperf3 tests in post #609 show the same single thread speed of around 8mbps the graph is taken from a HTML5 speedtest from TBB.
Could you guys not setup a test server of your own with private access or ip's of your choosing for testing in such cases ?
And as far as I am aware, there isn't any Public iperf3 uk servers (apart from bwctl) and I don't see a problem with the 10GB link above being saturated either as the server makes you wait till it isn't busy. as for routing to it, well that's your teams bag.
Re: Odd TBB test ?
18-05-2017 11:11 AM
@philcecchini you seem to have some sort of delay on your TBB single thread test, are you using QOS or is that a pc or network thing. It's by no means perfect for your line, But I've no idea what your using router/modem wise or pc spec etc, just curious. I see in a previous post that you was using a WDR-3600.
I'm using one with DD-WRT Firmware: DD-WRT v3.0-r31924 std (05/02/17)
Re: Odd TBB test ?
18-05-2017 11:26 AM
@30FTTC06 this is what i just got , unknown Gateway
- core2-hu0-18-0-0.colindale.ukcore.bt.net (62.172.103.16) 5.038 ms
