Odd TBB test ?
- Odd TBB test ?
Re: Odd TBB test ?
26-04-2017 8:59 AM
had a couple of good weeks all ok , the today psb-bng04. similar results over last 3 tests
http://www.thinkbroadband.com/speedtest/results.html?id=149319687012503529513
Re: Odd TBB test ?
26-04-2017 9:12 AM
http://www.thinkbroadband.com/speedtest/results.html?id=149319779216063415935
Re: Odd TBB test ?
26-04-2017 11:00 AM - edited 26-04-2017 11:02 AM
gateway psb-bng03. now and still same ?? and slow web page loading
http://www.thinkbroadband.com/speedtest/results.html?id=149320396218302417690
Re: Odd TBB test ?
26-04-2017 3:06 PM
Mine has been fine since my last moan.
http://www.thinkbroadband.com/speedtest/button/149321774290847481176.png
As expected!
I have no idea how it came to be fixed other than a day or so previous to my connection working properly, I saw 2 seperate Openreach guys messing with cables etc for a customer a few doors away... they were messing around for quite some time!, I also saw another guy at my cab on the same day.
Just to note my connection never dropped in the period before of after the visit.
Could more capacity have been added ?
Re: Odd TBB test ?
26-04-2017 5:57 PM - edited 26-04-2017 5:58 PM
well after BT outage today i get nice test would like to see this all the time PLEASE
gateway pcn-bng01.
http://www.thinkbroadband.com/speedtest/results.html?id=149322903423124493890
Re: Odd TBB test ?
26-04-2017 5:59 PM
So are you saying that your problems went away the same time as me then, a few weeks ago ?
Re: Odd TBB test ?
27-04-2017 7:57 AM
Yes @30FTTC06 past few weeks have been ok
it then started playing up but since outage yesterday its looks ok again , Time will tell
Re: Odd TBB test ?
27-04-2017 10:49 AM - edited 27-04-2017 10:49 AM
@rongtw Hey!
No changes on our side which could cause it. If you are fault free, then our current theory is that the differences are down to the different routing changes your connection has when it is routed to the different BNGs across the BT Wholesale network. If you want to help us investigate further, start a log of which BNGs you are connecting to when you do speed tests. We'll need both fast and slow. Don't post them on there until you've got a week or two of data. (We can't do much with individual speed tests, so they'd just be spamming the thread).
I've another suggestion which I'll PM you about.
Ex-Broadband Service Manager
Re: Odd TBB test ?
27-04-2017 11:01 AM
@Kelly will do from previous post did you see PSB BNG 03 and 04 were bad for me
Re: Odd TBB test ?
27-04-2017 12:57 PM
Ok thanks, It seems plusnet are pointing a finger at Openreach then seeing as they are clueless as to what happened!
Also I've been on various BNG gateways the same as you in the past few weeks, and they all seem to be trouble free.
Re: Odd TBB test ?
14-05-2017 12:39 PM - edited 14-05-2017 12:41 PM
bng02
Whats wrong????
Re: Odd TBB test ?
14-05-2017 3:05 PM
I see you have posted a Samknows graph with problems starting around April sometime.
Are you sure it's just Multithread tests ?
Try some tests with iperf3
Forward:
iperf3 -c bouygues.testdebit.info -p 5200
Reverse:
iperf3 -c bouygues.testdebit.info -p 5200 -R
Re: Odd TBB test ?
15-05-2017 6:13 PM
Results below, looks like an issue?
Connecting to host bouygues.testdebit.info, port 5200
[ 4] local 192.168.1.104 port 58971 connected to 89.84.127.53 port 5200
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 1.00 MBytes 8.39 Mbits/sec
[ 4] 1.00-2.00 sec 2.00 MBytes 16.8 Mbits/sec
[ 4] 2.00-3.00 sec 2.12 MBytes 17.8 Mbits/sec
[ 4] 3.00-4.00 sec 2.25 MBytes 18.9 Mbits/sec
[ 4] 4.00-5.00 sec 2.25 MBytes 18.9 Mbits/sec
[ 4] 5.00-6.00 sec 2.25 MBytes 18.9 Mbits/sec
[ 4] 6.00-7.00 sec 1.25 MBytes 10.5 Mbits/sec
[ 4] 7.00-8.00 sec 2.12 MBytes 17.8 Mbits/sec
[ 4] 8.00-9.00 sec 1.38 MBytes 11.5 Mbits/sec
[ 4] 9.00-10.00 sec 2.12 MBytes 17.8 Mbits/sec
[ 4] 0.00-10.00 sec 18.8 MBytes 15.7 Mbits/sec sender
[ 4] 0.00-10.00 sec 18.6 MBytes 15.6 Mbits/sec receiver
iperf Done.
Reverse mode, remote host bouygues.testdebit.info is sending
[ 4] local 192.168.1.104 port 59003 connected to 89.84.127.53 port 5200
[ 4] 0.00-1.00 sec 1.44 MBytes 12.1 Mbits/sec
[ 4] 1.00-2.00 sec 1.37 MBytes 11.5 Mbits/sec
[ 4] 2.00-3.00 sec 1.05 MBytes 8.85 Mbits/sec
[ 4] 3.00-4.00 sec 940 KBytes 7.70 Mbits/sec
[ 4] 4.00-5.00 sec 1.29 MBytes 10.8 Mbits/sec
[ 4] 5.00-6.00 sec 865 KBytes 7.09 Mbits/sec
[ 4] 6.00-7.00 sec 898 KBytes 7.35 Mbits/sec
[ 4] 7.00-8.00 sec 980 KBytes 8.02 Mbits/sec
[ 4] 8.00-9.00 sec 959 KBytes 7.86 Mbits/sec
[ 4] 9.00-10.00 sec 1012 KBytes 8.29 Mbits/sec
[ ID] Interval Transfer Bandwidth Retr
[ 4] 0.00-10.00 sec 11.0 MBytes 9.26 Mbits/sec 24 sender
[ 4] 0.00-10.00 sec 10.8 MBytes 9.06 Mbits/sec receiver
iperf Done.
Re: Odd TBB test ?
15-05-2017 6:21 PM - edited 15-05-2017 7:07 PM
So you have a problem with Single and Multithread then, so posting here will just add to confusion.
I expect that all your tests are from a quiet line and with a cable ?
Re: Odd TBB test ?
15-05-2017 6:31 PM - edited 15-05-2017 6:46 PM
Its a 80/20 FTTC line, directly connected to the router with a cable.
