Odd TBB test ?
- Odd TBB test ?
Odd TBB test ?
08-12-2016 6:32 AM - edited 08-12-2016 6:33 AM
any ideas,?
http://www.thinkbroadband.com/speedtest/results.html?id=148117859128221131322
2nd test ten mins later ?
http://www.thinkbroadband.com/speedtest/results.html?id=148117841115171968271
Re: Odd TBB test ?
08-12-2016 8:48 AM - edited 08-12-2016 8:53 AM
I'm also seeing issues.
Forced change overnight to pcn-bng01.plus.net (84.93.253.70) (Colindale)
http://www.thinkbroadband.com/speedtest/button/148118620145863337522.png
Did a gateway change to psb-bng02.plus.net (84.93.253.110) (Southbank)
http://www.thinkbroadband.com/speedtest/button/148118633122187931032.png
Normally the single test line is matching the x6 line and both are flat at the top end of the scale.
Have all the AG gateways been shut down now as these were my preferred gateway and gave decent test results?
This was what I was seeing up until Wednesday morning
pcl-ag03.plus.net (212.159.2.169)
http://www.thinkbroadband.com/speedtest/button/14772179361271683264.png
Re: Odd TBB test ?
08-12-2016 9:01 AM
@SpendLessTime must be a problem with psb-bng02.
Which gateway
You are currently connected to gateway psb-bng02.
This is located in Southbank Point of Presence.
Re: Odd TBB test ?
08-12-2016 9:04 AM
But pcn-bng01 is worse for me, look at the single test of 0.9 Mbps so the issue is in both Colindale and Southbank
Re: Odd TBB test ?
08-12-2016 9:06 AM
still no better ?
http://www.thinkbroadband.com/speedtest/results.html?id=148118781432428834245
Re: Odd TBB test ?
08-12-2016 9:12 AM
Plusnet having problems with single-threaded downloads? Wow. Never heard of that before
Let's just hope it doesn't take them eight months to fix it this time.
Re: Odd TBB test ?
08-12-2016 9:13 AM
There must be issues at these 2 data centres, I could never get my x1 and x6 lines back together without finding an AG gateway in the past.
Remember the packet loss threads are both from these 2 data centres. If the AG gateways have gone now then this looks like I'll be moving on next year as these tests clearly indicate traffic congestion at the 2 main data centres.
Re: Odd TBB test ?
08-12-2016 9:19 AM
traffic congestion ?? PN dont have traffic congestion
just reboot router , got same gateway
Re: Odd TBB test ?
on 08-12-2016 10:18 AM - last edited on 08-12-2016 10:24 AM by Mav
You don't need to reboot the router, just log into it and disconnect and reconnect the PPP session, then it wont have any impact on the line profile thinking its unstable etc.
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
Re: Odd TBB test ?
08-12-2016 10:24 AM
Re: Odd TBB test ?
14-12-2016 6:04 PM
TBB tonight, not impressed with the x1 test results
Re: Odd TBB test ?
14-12-2016 7:01 PM
Oh Dear
Re: Odd TBB test ?
14-12-2016 7:06 PM
Swapped gateway to pcn-bng04.plus.net (84.93.253.94) and have an improvement to
But it just shows how peak times affect some of the the gateways. The morning test on the old gateway was just like the test I've done now.
Re: Odd TBB test ?
14-12-2016 8:58 PM
LOOK at this !!!! gateway psb-bng04.
Re: Odd TBB test ?
14-12-2016 9:02 PM - edited 14-12-2016 9:04 PM
Same as mine in post 11.
Annoying isn't it?
