Safeguard won't stay enabled
FIXED- Subscribe to RSS Feed
- Everything else
- Safeguard won't stay enabled
Re: Safeguard won't stay enabled
09-12-2020 3:38 PM
I've been trying to enable safeguard but it won't stay 'on' and won't change the dns settings. Could you check my account. Thanks, Jon
13-12-2020 8:37 AM
Hi Kelly,
We've also had the same problem - would you be able to check our account? Our username is sarahw49
Many thanks,
Jack
14-12-2020 9:15 AM
Hi Kelly, this problem still isn't fixed for me... Has the change been applied to my account yet? Thanks.
16-12-2020 12:07 PM
I'm having the same issue. I've checked the DNS settings on the router so it's not that. It just simply won't stay turned on
Is there anything you can do?
17-12-2020 11:45 AM
17-12-2020 11:51 AM
@vindice13 Looks like one of our twitter support team got this cleared for you already. Can you try again?
Ex-Plusnet Jobsbody
17-12-2020 11:55 AM
Hi both,
I've raised a clean up task for you!
Ex-Plusnet Jobsbody
19-12-2020 1:06 PM
Hi Kelly, would you be able to work the magic on my account too please as we're also having the same issue. The username is benniecooj. Thanks!
29-12-2020 11:18 AM
05-01-2021 2:03 PM
05-01-2021 2:05 PM
@holmesgirl It looks like it's active for you now? Can you confirm all is ok?
Ex-Plusnet Jobsbody
05-01-2021 2:13 PM
05-01-2021 2:45 PM
Hey all! Should be fixed now. Please let me know if not.
Ex-Plusnet Jobsbody
06-01-2021 11:23 AM
Yes! Thank you!
07-01-2021 9:25 AM
Hi all,
Last night we've released a system change which should correct the issue which was preventing you all being able to turn Safeguard on. Fingers crossed, this should be the last we see of this issue!
Please flag up if you see any further issues though.
Ex-Plusnet Jobsbody
- Everything else
