Safeguard won't stay enabled
phish386
I am enabling Safeguard to my Fibre Broadband, and adding a website to block. The status icon on the Safeguard activation page changes Green to indicate changes saved and Safeguard is active. However when I return to Safeguard status is back to grey Off position. I have tried multiple times to switch on, but every time I return to safeguard page it is switched off again.
I am using BT Home Hub 6 router, everything else is standard. I checked DNS, it is using the correct primary DNS for safeguard. I waited overnight and no change.
Any advice?
Tags (1)
180 REPLIES 180
Fixes: 1,495
Re: Safeguard won't stay enabled
Moderators Note
This topic has been moved from Fibre to Everything Else
holmesgirl
I am also experiencing the same thing.
Tags (1)
JohnP79
I am having the exact same issue with the exact same router! Did you manage to get it fixed in the end?
Failing that - is anyone from PlusNet reading this and can help?
Thanks,
Tags (1)
JohnP79
I contacted PlusNet's helpline about this problem, and I was advised to try keeping my router switched off for an hour and a quarter after activating SafeGuard on the portal. I didn't expect it to work... and it didn't.
Another thing I tried: with my router switched off, I logged onto the portal from my smartphone using mobile data, and activated SafeGuard. On revisiting the page, again using my smartphone, I saw once again that SafeGuard had automatically and immediately been switched off again (without my router ever having been connected in order to have an effect).
PlusNet - please help!
JohnP79
I've just phoned the helpline again, and this time I was advised that Safeguard has not been working properly for a long time, and PlusNet knows about it.
I was advised to try netnanny.com instead and they told me it was free. It turns out it's chargeable, and device-based rather than filtering the whole network - so not really what I was looking for Sad
phish386
Tx for the update. I gave up in the end and blocked certain websites at router level and then use a VPN to get around if I want access.
uraken007
What a nonsense! sort it out Plusnet, we buy into you because you offer additional value added services and yet something as serious as safe guard doesn't work, people have children they want to to protect and yet they cannot because this doesn't work as advertised, i'll be moving very swiftly if this is not rectified ASAP!
Kelly
Fixes: 9
Hey all,
I'll take a look at this for all of you.  Can PM me over your usernames?
Kelly Dorset
Ex-Plusnet Jobsbody
hawmead
Thanks Kelly, done...
JohnP79
@Kelly wrote:
Hey all,
Hi Kelly - any joy?
Forumitus
When I spoke to them just now they sent these instructions - which don't make any sense!
Log in
Locate down the "Left" side - Under "Manage Account" - "Plusnet SafeGuard"
Click Here and follow the on-screen instructions to download the file.
Please Take note of the Serial Key provided - you'll need this for later on.
Open the downloaded file and select "Allow to make changes to device"
Await the installation to complete.
hawmead
I’m with you on this one, makes no sense whatsoever.  I logged in and found ‘manage your account’ ok, but no sign of any reference to safeguard within it! And even so, why do you have to install something on the pc? Surely this is under the control of the Plusnet servers? Besides which, I’m predominantly an iPad user 😉
come on Plusnet, give us a clue, what’s going on with safeguard? This has been going on for way too long now!!
Fixes: 577
Whoever you spoke to is confusing Safeguard with Plusnet Protect https://www.plus.net/broadband/extras/online-security/
Kelly
Fixes: 9
Hey all.
We think we know why this is happening and are working on a fix at the minute.  Will update here once we know more!
Kelly Dorset
Ex-Plusnet Jobsbody
