Safeguard won't stay enabled
Redbingo
Re: Safeguard won't stay enabled
Hi Kelly
I've been trying to enable safeguard but it won't stay 'on' and won't change the dns settings. Could you check my account. Thanks, Jon
jackm49
Hi Kelly,
We've also had the same problem - would you be able to check our account? Our username is sarahw49
Many thanks,
Jack
graham_s
Hi Kelly, this problem still isn't fixed for me...  Has the change been applied to my account yet?  Thanks.
vindice13
Hi Kelly
I'm having the same issue. I've checked the DNS settings on the router so it's not that. It just simply won't stay turned on
Is there anything you can do?
Kelly
Fixes: 9
@graham_s @lynncarson
Hi both,  please try activating Safeguard now?
Kelly Dorset
Ex-Broadband Service Manager
Kelly
Fixes: 9
@vindice13 Looks like one of our twitter support team got this cleared for you already.  Can you try again?
Kelly Dorset
Kelly
Fixes: 9
@jackm49 @georgepullan123
Hi both,
I've raised a clean up task for you!
Kelly Dorset
benniecooj
Hi Kelly, would you be able to work the magic on my account too please as we're also having the same issue. The username is benniecooj. Thanks!
Charlie280208
Please please can you help me with this same issue!!! My safe guard won’t stay enabled. I’ve been trying for months now!
Kelly
Fixes: 9
@benniecooj @Charlie280208  I've raised a request for you both.
Kelly Dorset
Kelly
Fixes: 9
@holmesgirl It looks like it's active for you now?  Can you confirm all is ok?
Kelly Dorset
Charlie280208
Thank you! I will keep checking x
Kelly
Fixes: 9
@georgepullan123
@jackm49
@tall_andy
@Charlie280208
@benniecooj
Hey all!  Should be fixed now.  Please let me know if not.
Kelly Dorset
holmesgirl
Yes! Thank you!
Kelly
Fixes: 9
Hi all,
Last night we've released a system change which should correct the issue which was preventing you all being able to turn Safeguard on.  Fingers crossed, this should be the last we see of this issue!
Please flag up if you see any further issues though.
Kelly Dorset
