Safeguard won't stay enabled
hawmead
Re: Safeguard won't stay enabled
Thanks Kelly
Forumitus
Hi Phish386
Can you explain how you did that?
Is it via the administrator/Hub Manager area?
I have a Plusnet router...
TIA
Simers1983
Same here, over 6+ weeks I've been phoning in 3 times now as im getting no calls back regarding getting this working. My 9 year old son has just found porn on the internet by accident and we've been trying so hard to get this safeguard activated. We now have to hide all devices before bed time.
Come on Plusnet! This is shocking!!!!
Kelly
Fixes: 9
@hawmead It looks like it's active for you now?  Can you confirm all is ok?
Kelly Dorset
Ex-Broadband Service Manager
Kelly
Fixes: 9
@Simers1983 Hi, what's happening for you?  Are you getting any error messages or anything when you try and turn safeguard on?
Kelly Dorset
hawmead
Hi Kelly, yes it’s all looking good now, thanks for progressing this
Simers1983
No errors at all, i switch it on, click save and close the page. It then automatically goes back to being off. It will not stay on. Turned off, restarted and even unplugged the router after doing so and still it switches to being off.
Kelly
Fixes: 9
@Simers1983 ok.  Have you just tried it again?  I want to see if the data on our side has changed.
Kelly Dorset
Simers1983
Just tried and again no luck. When i click save and refresh the web page it stays turned on, but if trying to access "blocked" pages i can still get on them. However when i close the page and log back on it says off.
JohnP79
No improvement here, I'm afraid...
Kelly
Fixes: 9
@Simers1983 and @Forumitus
Can you both try turning it on again please?
Kelly Dorset
Kelly
Fixes: 9
@JohnP79 We'll look at yours next if it worked for the previous two!  *finger crossed*
Kelly Dorset
Kelly
Fixes: 9
@JohnP79  We've done the fix on your account.  Could you try now?
Kelly Dorset
JohnP79
It's working a treat now - thanks Kelly!
Simers1983
Thanks so much Kelly! That's it now finally working! You're a star! What was the issue with it?
