Safeguard won't stay enabled
Re: Safeguard won't stay enabled
Hi Kelly
I've been trying to enable safeguard but it won't stay 'on' and won't change the dns settings. Could you check my account. Thanks, Jon
Hi Kelly,
We've also had the same problem - would you be able to check our account? Our username is sarahw49
Many thanks,
Jack
Hi Kelly, this problem still isn't fixed for me...  Has the change been applied to my account yet?  Thanks.
Hi Kelly
I'm having the same issue. I've checked the DNS settings on the router so it's not that. It just simply won't stay turned on
Is there anything you can do?
Fixes: 9
@graham_s @lynncarson
Hi both,  please try activating Safeguard now?
Kelly Dorset
Broadband Service Manager
Fixes: 9
@vindice13 Looks like one of our twitter support team got this cleared for you already.  Can you try again?
Kelly Dorset
Fixes: 9
@jackm49 @georgepullan123
Hi both,
I've raised a clean up task for you!
Kelly Dorset
Hi Kelly, would you be able to work the magic on my account too please as we're also having the same issue. The username is benniecooj. Thanks!
Please please can you help me with this same issue!!! My safe guard won’t stay enabled. I’ve been trying for months now!
Fixes: 9
@benniecooj @Charlie280208  I've raised a request for you both.
Kelly Dorset
Fixes: 9
@holmesgirl It looks like it's active for you now?  Can you confirm all is ok?
Kelly Dorset
Thank you! I will keep checking x
Fixes: 9
@georgepullan123
@jackm49
@tall_andy
@Charlie280208
@benniecooj
Hey all!  Should be fixed now.  Please let me know if not.
Kelly Dorset
Yes! Thank you!
Fixes: 9
Hi all,
Last night we've released a system change which should correct the issue which was preventing you all being able to turn Safeguard on.  Fingers crossed, this should be the last we see of this issue!
Please flag up if you see any further issues though.
Kelly Dorset
