Safeguard won't stay enabled
Fixes: 9
Re: Safeguard won't stay enabled
There was a bit of dodgy data associated with your accounts which was stopping it from working.  We've now got a fix for when it's reported to us, and I'm looking at a wider clean up to make sure any other people aren't affected in future.
Kelly Dorset
Broadband Service Manager
  • WELL DONE KELLY! Seems sorted now, thanks.
Hi Kelly, could you please also apply the fix on my account?  I’ve had the same problem with SafeGuard not switching on.  It seemed to start when I upgraded my fibre speed a few months ago, but that could just be a coincidence.
Thanks very much,
Fixes: 9
@graham_s PM over your username and I'll get it raised!   When did you upgrade to fibre, out of interest?
Kelly Dorset
This is happening to me too. Can you fix for me as well-have an 11 year old about to get his first mobile so keen to get sorted.
Hi I'm having problems with safeguard too. It's not blocking anything. I type in naked ladies shows me a whole load of images. I have 3 children and I don't want them to come across any of this. Let's me access porn sites too. Please help.
Fixes: 9
@lynncarson Hi!  PM over your username and I'll have a look for you
Kelly Dorset
Fixes: 9
@bitzy007 I presume you've tried to turn it on but it's turned itself off?  Can you check if it's still enabled?   If it's seems to be turning itself off, then I need your username and I'll have a look.
Kelly Dorset
Hi Kelly, the only issue we're having now is when we put in certain websites on the allowed list it still blocks the site. Is there anything that can be done about that? Thanks
Fixes: 9
@Simers1983 PM me over a bit more detail and I'll get someone to take a look.
Kelly Dorset
Safeguard is on, iv ticked all the categories to block content eg nudity, porn etc. Once I did that I restarted my router as it says it can take upto 2 hrs for it to work. I went back on did another search for 'naked ladies' the images that came up were disgusting. So safeguard didn't work.
Fixes: 9
@bitzy007 Hi, I've checked and it appears to be enabled properly.  Can you call up the call centre and discuss with one of our team?  They'll a bit more info to work out what's happening here.
Kelly Dorset
Fixes: 9
@lynncarson @graham_s
You are both affected.  I've raised an action to fix this for you.  Hopefully done early next week!
Kelly Dorset
🤞 Thank you for progressing it for me
I have the same problem.
Trying on the safegaurd , however later it turn off automatically. Not blocking any site at all, rally worrying about the kids.
