Strange moveable tile appeared on desktop
- Strange moveable tile appeared on desktop
23-01-2015 7:47 PM
I shut off my laptop last night with no issues. I yurned it on today and after about 5 minutes, a little grey tile appeared in the bottom right of the screen.
The tile can be moved around the desktop by right clicking and dragging. There are no properties to it and you can't double click it.
I am a careful surfer and I use Chrome as my broweser. I have Comodo running and have scanned the laptop. I have also used Spybot, Malwarebytes and Ccleaner to give it a good going over. I have looked in the processes box and can't find anything relevant and I have also checked all the startup entries to no avail. Finally there was a system restore to 4 days ago.
Anyone got any ideas what it may be as I don't even know what to Google for?
Mark
Mark
6 REPLIES 6
Re: Strange moveable tile appeared on desktop
24-01-2015 11:13 AM
To help identify which process has created the window, you can use Process Explorer.
Click and Drag the icon that to the right of the binoculars over the errant window, process explorer should then highlight the owning process in its list.
24-01-2015 11:46 AM
Thanks for that, I will keep that for further use. I found a (hopeful) solution which was to right click and alt F. Hopefully that is the end of it
Mark
Mark
24-01-2015 6:43 PM
Bet you're using Comodo.
Check here -
https://forums.comodo.com/install-setup-configuration-help-cis/invisible-prompt-merged-t109367.45.ht...
Check here -
24-01-2015 6:49 PM
Quote from: Marksfish I have Comodo running and have scanned the laptop.
I bet this gave it away
Thanks for the link. I am happier now I know that I am not the only one suffering from this whatever it is.
Cheers
Mark
24-01-2015 7:51 PM
Ha ha!
Just saw that strange C image on a post on the Comodo forums and thought, hang on, where have I seen that before?
24-01-2015 7:55 PM
It was spot on and just the answer I was looking for thanks. You da man
