Rechargeable Batteries with 20 year life span
- Rechargeable Batteries with 20 year life span
13-10-2014 5:18 PM
NTU researchers claim this new battery technology ( Titanium dioxide nanotubes ) has a whopping 10,000-cycle lifespan, meaning you can charge a battery 10,000 times before its max charge starts to reduce.
Possibly available within two years, an unnamed company already licensing the technology...
http://media.ntu.edu.sg/NewsReleases/Pages/newsdetail.aspx?news=809fbb2f-95f0-4995-b5c0-10ae4c50c934
Quote The benefits of fast charging need no explanation, but many of today’s smartphones and tablets won’t let you remove their batteries, essentially forcing you to buy a new device when the lithium-ion battery inside starts to fade after 500 or so charges.
A battery that lasts 20 years could dramatically change how long people hang on to their smartphones, especially with the mobile industry’s recent trend of decoupling hardware fees from services subscriptions.
Together, the combo could further reduce the two-year upgrade cycle so common in the mobile industry.
Re: Rechargeable Batteries with 20 year life span
07-11-2014 11:28 PM
08-11-2014 10:34 AM
Take a standard 44amp hour battery - charge to 70% in two minutes needs a whopping 924 amps
08-11-2014 10:44 AM
The time taken to recharge these is already a major issue (as is the limited number of cycles before they need replacing) and this won't really affect that without some extraordinary means of supplying enormous currents.
If you think petrol stations are dangerous places think about somewhere capable of delivering what would amount to megawatts of power (for a few minutes) to a single vehicle.
It's probably better to think about the power (Watts) required than the current as charging systems would probably connect at higher voltages to work effectively.
I don't know what power a typical electric car uses to run, but looking at the power output of petrol engines they are usually 100KW or more.
Just as a ball-park lets say an efficient average of 25KW while "cruising" and you want to replenish several hours (say 5) of driving use in 5 minutes (60:1) that would suggest recharging at 1.5MW......
For smaller low-consumption devices on the other hand it sounds promising.
08-11-2014 1:26 PM
So I guess for the tesla/jazz/leaf etc this would be a good option
08-11-2014 1:30 PM
Quote from: petecov44 I wonder if this will lead to faster car charging? I sure hope so!
Tesla motors quote 68 miles per hour of charging using dual chargers in what they call a type 2 outlet at home - that's an outlet capable of delivering 22kW which is about 90 amps at 240v or 55A with 400 volts if you happen to have a house with a three phase supply.
08-11-2014 3:50 PM
the petrol engine is only there to charge the battery and is not connected to the wheels so you get around 230mpg from it.
I fail to see how you can make that statement...
If a car is proplled by elastic band... then it will get NO miles per gallon
If a car is propelled by electricity...... then it will get NO miles per gallon. Regardless if the battery is charged during that journey, by the petrol engine...
The fact that the battery is charged by the petrol engine, has no bearing on the number of miles that the petrol engine travels... as it is only a passenger, and not actually powering/driving the wheels.
If you have a car that is only charged using the mains power supply, and has a petrol engine to provide the heat for the demisters, then you cannot, under any circumstances claim a Miles Per Gallon figure for that petrol engine... Can You ?
08-11-2014 4:04 PM
The fact that it goes indirectly to the wheel via a generator/battery/motor setup is neither here nor there in the calculation.
The interesting technology used in F1 shows that energy recovery in braking, exhausts etc. can make the overall setup more efficient, though whether 230mpg is achievable in a road car at present seems extremely unlikely.
If the batteries can also be charged up by plugging into the mains and a petrol engine tops up the batteries (as several designs do) then mpg is totally meaningless.
08-11-2014 4:30 PM
http://www.vauxhall.co.uk/vehicles/vauxhall-range/cars/ampera/index.html
Look at the benefits bit - does or does it not say 235.4 MPG - and does it not also say
“Combined/weighted” fuel consumption/CO2 figures calculated from two test results: one when the battery is fully charged and the other when the battery is discharged. The two test results are a weighted average, taking into account mileage range on battery power only, providing a figure in a variety of charge conditions. Extended range achieved by 1.4 litre 16-valve VVT ECOTEC® petrol engine generating electricity."
Argue with someone who cares. I was making a statement based on what I read.
09-11-2014 12:00 AM
09-11-2014 2:36 PM
09-11-2014 4:08 PM
09-11-2014 4:38 PM
I Note that there are many more plastic items on new cars such as bumpers so this will account for a reduction in rust but we can only judge what a new car made today will be like in 10 years time regarding rust.
09-11-2014 4:42 PM
Now sit down please - it is a Vauxhall that well known rust bucket brand in the past
09-11-2014 5:17 PM
