Rechargeable Batteries with 20 year life span
- Rechargeable Batteries with 20 year life span
Re: Rechargeable Batteries with 20 year life span
15-11-2014 11:13 PM
Quote from: shutter give it some power...
... generated by solar panels.
16-11-2014 5:13 AM
I have one of these hydrogen fuel cell toy car kits somewhere:
http://www.gizmag.com/go/5780/
Took about a week to generate enough H2 from solar to run it for about 5 minutes, scale that up and, well, it's not particularly effective or efficient...
Yes the hydrogen fuel cell itself is great for generating power, BUT, if you generate it from breaking up distilled water, it's going to take a lot more energy to accomplish than what you'll get back, if it were that easy, then we'd have sorted the energy crisis a looooooong time ago, but as it stands, it's one of those "You cannae change the laws o' physics Jim" things due to the effect of ever diminishing returns (100% in, 50% out, 50% in, 25% out, 25% in, 12.5% out, in other words, a losing battle), and if you want to get the most efficiently extracted hydrogen to fuel your cell, you have to take it from petrochemicals, which is about as green as tyre burning...
And if you're using solar panels to split water into H2 and O to fuel a cell to power a charger to recharge a phone, erm, skip the splitting & fuelling, charge your phone right off the solar panel, I do that myself, you get far fewer losses that way...
Physics; It's the Law.
16-11-2014 8:59 AM
Interestingly there is the "sulphur iodine" process for large scale manufacturing of hydrogen.
This is catalytically enhanced thermal dissociation of water using high temperature heat into hydrogen and oxygen. It has been proposed for use with nuclear reactors and solar ovens
@petecove44. As a conversion process I think batteries are better than what you have efficiency wise
To be is to do - Kant
do be do be do - Sinatra
16-11-2014 10:21 AM
16-11-2014 11:07 AM
http://www.maplin.co.uk/p/12v-modified-sinewave-230v-mini-inverter-with-5v-usb-a76kc
Doesn`t show a 3pin output... but would have thought it was there... and you could plug in your "normal" aa/aaa charger to that...
EDIT EDIT
different part number but £2 cheaper ! ! ! ...
http://www.maplin.co.uk/p/2-power-12v-modified-sinewave-175w-mini-inverter-with-usb-charging-socket-...
Or this one......
http://www.maplin.co.uk/p/75-w-mp75-travel-inverter-single-socket-a20fc
16-11-2014 11:30 AM
16-11-2014 11:39 AM
Quote from: jelv Has anyone here any experience/recommendations for recharging AA/AAA batteries from a 12V supply.
Ansmann do an AA/AAA charger (Ansmann Global Line EC 800) that comes with a 12v adapter. I have no experience of that model, but I use Ansmann mains chargers and they work very well. Seems to be cheap enough £16.99 with batteries at http://www.wexphotographic.com.
16-11-2014 12:12 PM
Quote from: twocvbloke we'd have sorted the energy crisis a looooooong time ago, but as it stands,
People who try get murdered by the big companies because it would end their profits. This is why the liked of Rossi are in hiding in secret locations but are still bringing out their cold fusion tech.
One scientist recently died after being in hiding since 1956.
I also agree for charging off the panel directly and I do that also but there are some places I go where a solar panel would be useless. This is where a large battery pack and the reactor are a god send especially if I am there for a few days
16-11-2014 12:15 PM
Quote from: PeterLoftus @twucvbloke
Maybe, Maybe not time will tell as I have not really had a chance to test them all together yet at the same time. I do more than charge my phone but the reactor is the last resort when the battery packs are depleted. For the gear I carry I have a few 50,000mAh packs (probably 30000 in reality) and the reactor which has it's own 3800MaH battery in it - obviously use as storage from the output also but being able to power everything and still fill up the pack means I can use it and then recharge it all and use it - so getting even more life.
You are all probably sat there thinking "where the hell are you when you do this in a cave?" You wouldn't be far wrong either
16-11-2014 12:22 PM
Quote from: wisty
Just to add to this I have a 30 minute charger I bought from Ebay for £18 and that too has a 12v DC adapter. You get 4 batteries with it also which are good ones but I can't find it for sale anymore so the Ansmann one would be the best buy.
here's the one I have anyway.
16-11-2014 12:41 PM
Quote from: petecov44 People who try get murdered by the big companies because it would end their profits. This is why the liked of Rossi are in hiding in secret locations but are still bringing out their cold fusion tech.
You actually believe that rubbish?? The reason these people go "into hiding" is because the things they're "developing" do not work!! If I created something, made bold claims about that could not be backed up scientifically, I'd go into hiding to escape the ridicule from intelligent people who can see that these creations are blatantly rubbish!! The only people who actually believe in the conspiracy theories are the ones who wear foil hats and smoke cannabis...
Over-unity is impossible, there is no way in this universe that you can put 100% energy and get 110% back, it's just completely impossible...
16-11-2014 7:17 PM
I believe in the works Rossi does. That's up to me.
I'm happy to power some things via solar and Hydrogen. It's bought my bills down to £30 a quarter with standing charge so I am happy to carry on this way. I choose to recharge these Hydrosticks. I could just take them back to Maplins and get free replacements but I would be doing that every other day.
Also i need something that will run underground for as long as I need it too.
Each to their own.
16-11-2014 8:24 PM
The way you're doing things from how you describe though is very inefficient, imagine if you will, a power station using steam to drive a turbine, the turbine drives a generator, the generator charges a battery, the battery then powers a motor, the motor drives another generator, generator drives the grid, that's basically what you have there, creating excessive losses where none should exist, where in reality (and what smart people do) is increase efficiency and skip the wasteful steps so that steam drives the turbine that drives the generator that drives the grid, just as you could use solar to charge a battery to drive your device(s), that alone would save a lot of time and quite literally a lot of energy...
Simple primary-school maths on turning water into H2 and O states that for every 1 Amp of electricity you use, you only get 0.5 Amps equivalent returned, depending on the efficiency of your fuel cell. With some simple figures, using batteries charged via solar means to recharge the battery, you have to put in 120% of the capacity of the battery to fill it to 100% charge, so a 50Ah SLA battery for example needs 60Ah to charge, then half of that 60Ah used to charge the battery is thrown out the window as waste oxygen in your generator, so you get 30Ah lost, but as the battery only has 50Ah to give, then it's 25Ah of equivalent power left over when the H2 is run through the fuel cell assuming 100% efficiency (impossible) but the actual figure would be far less...
To me, I'd say that sticking to what the battery has stored in it is much more efficient, and not to mention higher capacity too, as-is you're basically wasting your money, I'd be very interested to know how much you've spent on all this equipment to compare it to the average household electricity bill...
16-11-2014 8:55 PM
2. I didn't spend a penny, so shove that up your arse and Multiply it!
[Moderator's note by Dick (Strat): Full quote of preceding post removed, as per Forum Rule]
17-11-2014 7:56 AM
And I couldn't care less if you sit in the dark, you've got your priorities sorted it seems, personally though I'd pay the electricity bill first then have internet access, not the other way round, simple logic...
