ISP PlusNet Launch Faster Hub Zero 2704n Broadband Router
- ISP PlusNet Launch Faster Hub Zero 2704n Broadband...
Re: ISP PlusNet Launch Faster Hub Zero 2704n Broadband Router
27-04-2015 10:41 AM
Quote from: ectoplasmosis So, is there any way to enable this feature on the 2704n?
In Matty123123's unlocked firmware, I guess. Plusnet's firmware has this page locked down, you can't access it.
Quote from the Sagemcom's manual, page 164:
Field Action/Meaning Default value Brandwidth Select the bandwidht 20 MHz or 40 MHz. 20 MHz
Darsh
27-04-2015 10:46 AM
06-05-2015 10:23 PM
Quote from: Darsh
Where can I get hold of this modified firmware, and can anyone confirm that the channel width setting is indeed able to be changed?
Many thanks
07-05-2015 8:23 AM
07-05-2015 11:23 AM
07-05-2015 2:05 PM
No reply as yet, one word, disappointed.
07-05-2015 2:11 PM
Quote from: Anotherone see http://community.plus.net/forum/index.php/topic,137629.0.html ; reply #50 specifically.
Please stop pushing this in peoples faces as a solution, as of yet I've seen no evidence of anybody using the stock firmware with ssh access or wan ping enabled on FTTC.
07-05-2015 3:39 PM
Quote from: rongtw Is PN Ever going to update the router firmware so we can use TBB graph,s ???????
maybe not.
BT dont allow pings on their homehub's as apparently its bad for security, given plusnet is owned by BT they may have the same mindset.
07-05-2015 3:47 PM
07-05-2015 4:09 PM
Quote from: chrcoluk BT dont allow pings on their homehub's as apparently its bad for security, given plusnet is owned by BT they may have the same mindset.
it's no more secure than removing the number from the door of your house and expecting the house to be invisible to burglars.
07-05-2015 4:14 PM
07-05-2015 4:37 PM
Can you, indeed, set up a DMZ on this router?
07-05-2015 5:52 PM
08-05-2015 2:25 AM
And what a load of cobblers that is.
Quote from: 11110_110
Oh excuse ME Mr Binary, the poster asked a question and I given the poster the answer they wanted
Quote from: ectoplasmosis Where can I get hold of this modified firmware
10-05-2015 4:05 AM
Quote from: 11110_110 Is that your great solution then ?
It's a suggestion that may help some people, I'm trying to be helpful, What are you doing?????
{Why do some people just have to be so negative about well-intended suggestions, especially if they don't offer anything better themselves? Sheesh, [censored] !}
