ADwin configuration protocol
- ADwin configuration protocol
16-10-2015 7:24 PM
I've got a Windows 8.1 machine emitting one of these every 2 seconds as a broadcast to 255.255.255.255
How do I prevent Windows broadcasting ADwin messages?
I know nothing about Windows 8.
Re: ADwin configuration protocol
16-10-2015 7:27 PM
17-10-2015 2:24 AM
18-10-2015 5:23 PM
18-10-2015 11:04 PM
There seem to be a variety of things which this thing can do - but they all duplicate existing functionality.
(and sometimes interferes with the ARP protocol).
I will look into it tomorrow whilst it's normal user is out.
19-10-2015 12:41 AM
19-10-2015 1:19 AM
I hate the fact it doesn't "just work".
Last time I looked it had ip addresses, DHCP, WINS etc etc
19-10-2015 8:16 AM
Does the owner of the PC know why it is installed?
19-10-2015 8:18 AM
19-10-2015 4:09 PM
For example I tried going to Config the Wifi - but it claimed to have downloaded about 1.5 GBytes on wifi in the 5 mins I'd had it switched on for.
I eventually managed to look at the network setup and it looked very similar to how I remember it when I used Windows 3.1 (or NT4).
It even had NetBIOS
The PC appears to start and shutdown remarkedly fast, considering it's Windows - so I don't think there are any wholesale virus issues.
But as I say, it all appears to be done just to confuse.
19-10-2015 6:19 PM
19-10-2015 7:14 PM
Have to admit it doesn't appear to continuous (i.e. its not doing it right now).
19-10-2015 8:08 PM
19-10-2015 8:12 PM
19-10-2015 9:10 PM
ARP works perfectly well on a "small" network, especially if you have a single gateway.
