Blocking gambling sites.
PowerLee
Anyone know if there is any way to block gambling sites from Plusnets end OR via my user account dashboard?
If not then any easy way to nobble a Windows 7 machine running IE 11 to block gambling but still allow access to Faceache?
No longer a Plusnet customer due to Openreach incompetence - Moved to Zen via CityFibre for symmetrical 500Mbps fibre broadband & digital voice.
10 REPLIES 10
Re: Blocking gambling sites.
That would depend on what router you had I guess, but you could edit the Windows 7 host file and have it redirect the URLs to either local host or some other site.
bet365.com 127.0.0.1
But this approach is only as smart as the user using the Win 7 machine, so if they have any tech sense then it might not be enough. Your best bet, no pun intended, is to block it at the firewall so request never exit the building.
minkey
Hi
PlusNet Safeguard should give you what you want.
https://portal.plus.net/my-account/safeguard/
Jeff
Yep, that looks useful, didn't even know it existed.
PowerLee
Cheers for all the ideas  Smiley
The Plusnet Safeguard looks interesting, do you have to use the Plusnet supplied router for it to work or is it blocking at Plusnets end?
Ive just turned it on remotely via my phone at work & set it to block gambling sites, ill have test of it later when I get home & back on my WiFi.
Fixes: 1,495
it uses DNS filtering, so as long as your devices are using PNs DNS then it should block it..
PowerLee
Nice one, thanks  Cool
PowerLee
Just had an email appear saying my Safeguard settings have been changed, thats useful to have  Cool
drunkenmonkey
until whomever wants to bypass the safeguard settings changes the DNS settings on their device Wink
PowerLee
The person in question I'm blocking isn't that smart with computers  Wink
drunkenmonkey
Cheesy Grin
