ISP PlusNet Launch Faster Hub Zero 2704n Broadband Router
- ISP PlusNet Launch Faster Hub Zero 2704n Broadband...
Re: ISP PlusNet Launch Faster Hub Zero 2704n Broadband Router
02-04-2015 6:13 PM
02-04-2015 6:40 PM
03-04-2015 10:59 AM
Unless I have completely lost the plot Jeremy, your last replies do not seem to be related to crazydan7 whom you are probably confusing.
I assume they relate to Veri & 11110_110 posts, but you could make that clear. What Wireshark has to do with passwords is beyond me!
@crazydan7
Don't forget the passwords are case-sensitive, you might have made an error somewhere. If all else fails, do a factory reset and start again.
03-04-2015 11:52 AM
03-04-2015 5:23 PM
Drop me a PM if you are and don't want to say which characters in a public forum and I'll try a bit of experimentation.
03-04-2015 5:42 PM
03-04-2015 6:08 PM
03-04-2015 6:14 PM
03-04-2015 7:35 PM
Quote from: vilefoxdemonofdoom Since 192.168.0.xxx is a different network to 192.168.1.254 it's hardly surprising...
Foxy, I've changed my ip range for my router to 192.168.0.254, I hope that brings a little clarity to the fore.
22-04-2015 11:23 PM
I was assured by Plusnet sales staff that the router can support a 300Mbit link speed, which using 802.11n at 2.4GHz would require a 40MHz channel width with SGI enabled.
Having set the WiFi Mode to "up to 300Mb/s", I am not seeing 40MHz channel width to be an option. None of my devices link over 144Mbit/s and doing a WiFi scan shows the network as supporting 20MHz width only. Even on the router "Helpdesk" page the following is written, indicating that the router is still set to 20MHz channel width: 22 - Wi-Fi connections: Enable(802.11 b/g/n(up to 300 Mb/s))20 MHz
So, how do I enable 40MHz channel width, and achieve the 300Mbit link speed as advertised? Plusnet support are none the wiser...
22-04-2015 11:51 PM
I wouldn't expect more than 150M with 2704N - I doubt it has more than two antennas.
Has anyone seen more than 150M with 2704N's wifi?
Darsh
23-04-2015 12:14 AM
Setting it to 300Mbit/s doesn't seem to enable 40MHz channel width however...
23-04-2015 12:30 AM
Could you please provide a link confirming that 2704N has four antennas?
Darsh
23-04-2015 12:39 AM
25-04-2015 6:59 PM
Anotherone: I've tested it with several devices, both Macs and PCs, with 802.11n and ac chipsets, distance/signal quality is not an issue. None will use 40MHz channel width.
So, is there any way to enable this feature on the 2704n? Has anyone actually been able to achieve link speeds over 150Mbit/s?
