ISP PlusNet Launch Faster Hub Zero 2704n Broadband Router
- ISP PlusNet Launch Faster Hub Zero 2704n Broadband...
Re: ISP PlusNet Launch Faster Hub Zero 2704n Broadband Router
10-05-2015 4:33 AM
[Moderator's note by Dick(Strat) Avoidance of swear filter removed.
[My apologies for 'going into one', was caught in a bad mood]
10-05-2015 7:13 PM
Now...
Can you man-up! and pm me what you said about me, or I'll ask a mod to, either way I would like to know.
10-05-2015 7:26 PM
11-05-2015 2:59 AM
Quote from: 11110_110 Can you man-up! and pm me what you said about me, or I'll ask a mod to, either way I would like to know.
No need for a PM 1110_110, I merely expressed my upset at your dismissal of my suggestion (but being so late and with me being tired and stressed I did resort to mild inappropriate language, for which I unreservedly apologise).
No, I'm not going to 'man-up' as you put it as there is no necessity for PMing and I don't have any insecurities about myself, nor do I see any point in taking any argument out of view (or continuing it pointlessly for that matter).
I can understand the potential security risks of DMZ (why on earth didn't you just make that point?) but many people have equipment (an old laptop or RPi for example) which could be set up as a ping responder if my suggestion is viable - I don't know if it would work but if it would then it could provide a means to do something that people want to achieve - I just found your response unnecessarily dismissive without explaining why.
11-05-2015 1:40 PM
12-05-2015 11:44 AM
Quote from: Anotherone He just swore with asterisks I believe, Dick got there before I read it.
He also appears to have Amnesia as well, as he can't remember what he Edited.
14-05-2015 4:25 PM
Very Sorry.
16-05-2015 8:31 PM
The interface on mine accepts the change, saves it, remembers it on reboot etc - but the reality is that whatever channel I select, it is actually always transmitting on channel 1
"Auto" also results in channel 1
EDIT - update to this
It would appear that this is only an issue if you change the wireless mode to up to 300Mb/s which probably wouldn't work anyway on this router - setting to 144Mb/s works as expected.
02-06-2015 3:44 PM
3Mb FTTC
02-06-2015 4:18 PM
Or dont PN wont us to be able to check this
02-06-2015 6:38 PM
02-06-2015 7:50 PM
07-06-2015 4:36 PM
Quote from: Bob There are isolated instances of the incorrect MTU being set by the TR069 ACS servers when a router is first provisioned. I made an ACS change that should have fixed things following a factory reset/reprovision. I don't know a great deal about the problem but I'm led to believe that it's been addressed in the next revision of the Plusnet 2704n firmware.
07-06-2015 8:22 PM
07-06-2015 8:52 PM
