FTP Access to 1&1 Website via FireFTP - SORTED
Oldjim
Fixes: 63
This is a bit odd
I normally connect to the site using FireFTP in Firefox and this still works for my Plusnet hosted site and my site hosted on TSOHost
I hit major problems with my 1&1 hosted site - first it wouldn't carry out a directory listing and when it eventually did I couldn't switch between folders
I contacted 1&1 and we went through all the usual troubleshooting steps to no avail and in the end I downloaded Filezila and it all works fine
Any idea why FireFTP stopped working - could it be that the upgrade to Firefox 47 is the problem
4 REPLIES 4
Oldjim
Fixes: 63
Re: FTP Access to 1&1 Website via FireFTP - SORTED
I went to here https://answers.squarespace.com/questions/26259/how-do-i-connect-fireftp-to-sftp.html and found that the information I had been given for the settings wasn't correct
Putting them in as per this link - difference is that instead of prefixing the hostname etc. with sftp I just put in the hostname etc. and selected  SFTP as Security
7up
Fixes: 17
OJ are you accepting your own solutions now? lol
VileReynard
Fixes: 20
Is this signature any good?
Oldjim
Fixes: 63
@7up where the solution may help somebody else - Yes
@VileReynard I wouldn't know as I have them switched off
