WTH!
- Feedback
- Plusnet Feedback
- WTH!
Re: WTH!
11-11-2011 9:31 PM
You should of mentioned the noisy phoneline first, as i said before the two problems usually go together. (but if you dont know, you dont know, if theres an issue with the phone NEVER mention broadband, sort that out AFTER if theres still a problem...)
If you have another microfilter, can you swap it out with another to see if its just a dodgy filter thats causing the problem? (and as said above, try removing the router to see if its still noisy..)
You can try a "Quiet line test" on the phone at any time.. Dial 17070, then "option 2" when prompted. you should hear a 'beep or click' and the line should then go perfectly silent (this is what an engineer would do first to 'hear' the noise on arrival..) if its not *perfectly quiet* i'd raise a phone fault (might be worth plugging JUST your phoneline in for a few mins, to make sure its not BB affecting)
Regards
Re: WTH!
11-11-2011 9:39 PM
Re: WTH!
11-11-2011 9:46 PM
Re: WTH!
11-11-2011 9:47 PM
Re: WTH!
11-11-2011 9:55 PM
While you've got a problem with the phone, complaining about the broadband is a waste of yours and everyone else's time - broadband will never work properly over a line which doesn't work properly for voice.
Re: WTH!
11-11-2011 10:02 PM
Re: WTH!
11-11-2011 10:04 PM
Quote TalkTalk about the phone line and being told there was nothing wrong
Unfortunately the problem there was TalkTalk, generally dealing with people who havent got a clue what they're doing
as Jelv said, as the phone issue is sorted, the broadband should become stable (and usually faster
Regards
Re: WTH!
11-11-2011 10:15 PM
only been with plusnet a week or so and had more help than in all of the 4 years was with TalkTalk
Re: WTH!
11-11-2011 10:55 PM
Speedtest results :-
Download speedachieved during the test was - 202 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :3264 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 250 Kbps
Router Info
DSL Connection
Link Information
Uptime: 0 days, 0:14:25
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,108 / 3,584
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,264
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 4.08
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 22.5 / 46.5
SN Margin (Up/Down) [dB]: 25.0 / 16.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 47 / 0
Loss of Signal (Local/Remote): 2 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 33 / 0
FEC Errors (Up/Down): 0 / 495
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): 0 / 0
Re: WTH!
11-11-2011 10:59 PM
Re: WTH!
11-11-2011 11:04 PM
Will go and change the micro filter now., anything to find a solution lol
Changed the filter, just the same, once the router gets established, there's noise on the phone, like a hissing noise.
Re: WTH!
12-11-2011 12:24 AM
Re: WTH!
12-11-2011 12:50 AM
I'd agree with Jelv on trying another router if you have one... Plusnet can probably send you out a 'test' router to try, although you'll have to wait until Monday now until someone is around to sort this out (if its possible, theyve done it before so i dont see why not
a quick question, what sort of phone is it? cheap cordless phone? wired? if its cordless, does moving the base away from the socket remove the noise?
Regards
Re: WTH!
12-11-2011 10:05 AM
I've got the router and phone plugged into the master socket now, I only moved them onto the extension so that I could use the ehternet cable for the speedtest, where the master socket is, is impossible for me to stand, with laptop cradled in my arms, as am disabled and have to use a stick to walk or stand for any length of time lol!
It's a cordless phone, twin handsets, wasn't exactly cheap but not top of the range either. There's no noise on the phone at all, until the router gets its act into gear. As soon as the router is fully lit and running, then the noise starts
Re: WTH!
12-11-2011 4:48 PM
