WTH!
- Feedback
- Plusnet Feedback
- WTH!
Re: WTH!
15-11-2011 11:13 AM
Thanks for the help everyone, I know I get a lil uppity, but its more frustration at my own inability to make things work lol
Re: WTH!
15-11-2011 11:19 AM
Thanks for your patience over this issue
Re: WTH!
15-11-2011 12:00 PM
That seems to have worked. I've upped the profile on our side to 5000 now so you should see this take effect in the next 15 minutes.
Jojo
Re: WTH!
15-11-2011 5:11 PM
I remember when I had my phone plugged in, when someone rang me, the internet dropped out, of course now I have my phone unplugged, I can't tell if someone if calling
Also, this is about the time all the schoolkids are logging in, and to be honest, we did have issues a while back because w detected that about 20 kids would all be logging in, at the time we wre ALL with TalkTalk!
May be a load of nonsense
Re: WTH!
15-11-2011 5:56 PM
If you have any energy left, you can plug a filter into the test socket and use the phone.
can you get somebody to look at the wires in the junction box?, you should only have two wire going out in sockets 2 and 5. look at this site for info http://www.kitz.co.uk/adsl/socket.htm
wish I was up in County Durham,on holiday could come round and do the job for you
Re: WTH!
15-11-2011 8:13 PM
Quote from: carolej I remember when I had my phone plugged in, when someone rang me, the internet dropped out
That is really significant. A test you can do yourself easily if you have a mobile phone. Pull up the router stats page, dial your number and watch to see if the router is affected while you can hear it ringing on the mobile. With a bit of luck it will drop out which would then be something solid to show an engineer.
Re: WTH!
16-11-2011 10:47 AM
Definitely leave it in the test socket, but as jelv says you could do with trying the phone to see if it's still affecting it.
Jojo
Re: WTH!
23-11-2011 10:58 PM
Broadband was good for a few days, some minor issues, tonight tho, its been quite bad, took ages to do the speedtest, which seems to have changed, results here
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
6 Kbps
0 Kbps 4000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 6 Kbps
For your connection, the acceptable range of speeds is 1200-4000 Kbps.
Additional Information:
Your DSL Connection Rate :3561 Kbps(DOWN-STREAM), 961 Kbps(UP-STREAM)
IP Profile for your line is - 3141 Kbps
Upload Speed
711 Kbps
0 Kbps 961 Kbps
>Upload speed achieved during the test was - 711 Kbps
Upstream Rate IP profile on your line is - 961 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
Re: WTH!
24-11-2011 9:56 AM
I'll see if I can get someone to look into this again for you.
Jojo
Re: WTH!
24-11-2011 10:35 AM
I am trying to stay positive, but my first month with Plusnet hasn't been great, the phone has been all but unusable, in fact has remained unplugged most of the time, I only used it to ring tech support last night because my mobile was low on credit, and the broadband has been a pain in the neck, however I am reminded that my next bill is due next week, its not good paying for a service that isn't up to scratch, although I know you are all doing your best to sort it.
Would I recommend you to a friend....um not at the moment, give me another month or so to see if this really can be sorted out eh
Re: WTH!
24-11-2011 11:14 AM
I realise you may be being put off by the messages about the £60 charge, and thought I should advise that this will only be charged if an engineer attends and finds the fault to be caused by your internal wiring or equipment.
Given the tests you've done with a single corded phone in the master socket (and also the same with the router) you've proved that the fault must be external to your premises. The charge is issued directly to us and then if validated passed on to the customer, however we have the option to reject - which we will do provided (as you have) that the tests have been done.
Basically I'm saying you've nothing to worry about regarding the engineer charges.
Hope that helps reassure you.
Re: WTH!
29-11-2011 7:19 PM
Today I get texts and emails saying my issue is resolved...so resolved I have had to connect to my neighbours broadband to send emails!
here's the last speed test
FAQ
Results Image not loaded
Download Speed
180 Kbps
0 Kbps 4000 Kbps
Download speedachieved during the test was - 180 Kbps
Your DSL Connection Rate :3936 Kbps(DOWN-STREAM), 1024 Kbps(UP-STREAM)
IP Profile for your line is - 3472 Kbps
Upload Speed
156 Kbps
0 Kbps 1024 Kbps
>Upload speed achieved during the test was - 156 Kbps
Upstream Rate IP profile on your line is - 1024 Kbps
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
I can tell you now, I am not paying another penny until someone sorts this out.
Re: WTH!
29-11-2011 7:49 PM
Quote from: carolej I can tell you now, I am not paying another penny until someone sorts this out.
I sympathise! Unfortunately that is not how things work. If you stop paying, Plusnet will stop pushing BT to fix the problem - and whichever ISP you're with, you will face the same problem. It's far better to stick with Plusnet: keep pushing them to keep pushing BT (and keep doing the seemingly-pointless tests they ask for), keep records of everything that everyone has said and done (or not done) including dates, times, names, organisation etc. Then once they finally sort the problem (or say there's nothing more they can do, and yet you can prove the problem still exists), go through the complaint procedure and obtain compensation for all the time and money you've spent sorting it out and all the time you've been without a useable internet connection (and only if this procedure fails, you can go to the independent ombudsman). Only once you've done all this, would it be advisable to consider leaving.
Frustrating I know. All due to the way the British telecoms industry is structured, thanks to BT's privatisation.
You may also want to seek advice as to whether you can get any help due to your disability - it might be discrimination that you can't get your broadband sorted because you can't get at your phone socket etc to do the tests your provider is asking you to do. Try the CAB: http://www.citizensadvice.org.uk/
Re: WTH!
29-11-2011 8:00 PM
So I guess I have to go on paying for a shocking service while having to use my neighbours Sky broadband!
And they have the nerve to email me asking me to recommend them to my friends!
Re: WTH!
29-11-2011 8:01 PM
Our system just hadn't picked up your new profile yet. I've changed it manually now for you to 3000 so you should see the increase in the next 15 minutes.
Jojo
