WTH!
- Feedback
- Plusnet Feedback
- WTH!
Re: WTH!
04-11-2011 3:23 PM
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :5312 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
Re: WTH!
04-11-2011 3:26 PM
Re: WTH!
04-11-2011 3:39 PM
Re: WTH!
04-11-2011 3:56 PM
Re: WTH!
04-11-2011 5:07 PM
Re: WTH!
07-11-2011 3:48 PM
Download speedachieved during the test was - 88 Kbps
Your DSL Connection Rate :3776 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
Am going to look at the router now.
Seriously, I set an album download at 06.50 this morning, 14 songs and 1 video, it managed to finish downloading at around 09.30 and I was unable to do anything else while it downloaded. It really isn't good, and having to have the eithernet attached is making things less convenient for me.
DSL Connection
Link Information
Uptime: 0 days, 0:13:24
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,096 / 3,872
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,776
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 1.67
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 23.0 / 47.0
SN Margin (Up/Down) [dB]: 25.0 / 10.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 969
CRC Errors (Up/Down): 0 / 6
HEC Errors (Up/Down): 0 / 99
Re: WTH!
09-11-2011 10:38 AM
Shortly after you posted the above your BT profile jumped up to 3000 to match what is set on our systems, so you should have had a fairly significant improvement since then. Has that happened, or is it still running slowly?
Re: WTH!
10-11-2011 3:27 PM
Am now off to start a new thread, for positive feedback
Re: WTH!
11-11-2011 5:36 PM
speed test results :-
Download speedachieved during the test was - 132 Kbps
Your DSL Connection Rate :320 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 250 Kbps
Router info
DSL Connection
Link Information
Uptime: 0 days, 14:08:21
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,068 / 544
Bandwidth (Up/Down) [kbps/kbps]: 448 / 320
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 304.09
Output Power (Up/Down) [dBm]: 12.0 / 16.0
SN Margin (Up/Down) [dB]: 24.0 / 6.0
Loss of Signal (Local/Remote): 65,538 / 0
Error Seconds (Local/Remote): 65,638 / 0
FEC Errors (Up/Down): 0 / 74,844
CRC Errors (Up/Down): 0 / 139
HEC Errors (Up/Down): 2 / NA
Come on guys
Re: WTH!
11-11-2011 7:22 PM
Re: WTH!
11-11-2011 7:33 PM
just seems that when i post on here things piick up and then it all goes back to usual
Re: WTH!
11-11-2011 7:36 PM
Re: WTH!
11-11-2011 8:31 PM
Re: WTH!
11-11-2011 9:12 PM
Quote there's always noise on the phone, is why i never use it
noisy phonelines more than likely means theres a "voice fault" on the line (e.g. an issue regarding the voice service), if theres an issue with the voice service, 99% of the time theres an issue with the broadband service.
It may require you raising a phone fault, and getting an engineer to come take a look at the line itself, what sort of noise is it? Popping? Hissing? Crackling?
Regards
Re: WTH!
11-11-2011 9:23 PM
