WTH!
carolej
Re: WTH!
You say that every time Jojo, oh we've changed this, then I have to complain again, and you change it again.  How about you make it so it actually stays where its meant to be, and gives me the service you are "so proud of", instead of every other day me having to login to my neighbours router.  Of course, you'll be absolutely red hot at taking the money from my bank account!
jojopillo
Re: WTH!
Hi carolej,
I know it may seem like that and I'll certainly do everything I can. I can only change it on our side if it's changed on the BT system. If you stay in the test socket then I don't see why it won't remain stable. Let me know if the speed hasn't kicked in.
Jojo Smiley
carolej
Re: WTH!
The BT engineer said there is nothing wrong with the socket and put the face plate back on.
Download speedachieved during the test was - 206 Kbps
For your connection, the acceptable range of speeds is 1200-4000 Kbps.
Additional Information:
Your DSL Connection Rate :3936 Kbps(DOWN-STREAM), 1024 Kbps(UP-STREAM)
IP Profile for your line is - 3472 Kbps
carolej
Re: WTH!
Router stats
DSL Connection
Link Information
Uptime: 1 day, 10:53:59
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,084 / 3,936
Bandwidth (Up/Down) [kbps/kbps]: 1,024 / 3,936
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 729.18
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 26.0 / 44.5
SN Margin (Up/Down) [dB]: 11.0 / 11.5
Loss of Framing (Local/Remote): 686 / 0
Loss of Signal (Local/Remote): 131,073 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 196,609 / 0
FEC Errors (Up/Down): 534 / 2,838
CRC Errors (Up/Down): 259 / 122
HEC Errors (Up/Down): 147 / 776
Chris
Legend
Fixes: 169
Re: WTH!
Can you try another speed test in 5 minutes time for me please?
As for the reimbursement you've asked about, I'll sort that out for you when I'm back in the office tomorrow morning.
carolej
Re: WTH!
Yes I'll do that.
Thank you.
Chris
Legend
Fixes: 169
Re: WTH!
If the speed hasn't improved in a few minutes time, please just try a single power off and back on of the router (this would be better done through the router configuration pages if you know how to do that).
I've also responded to your ticket now about the goodwill gesture.
carolej
Re: WTH!
The speedtest says i can't run another for an hour.
Yes I know how to reboot the router through its page.
Shall i wait for the hour to pass?
Thank you, I will have a look shortly.
Chris
Legend
Fixes: 169
Re: WTH!
You can just try a quick speedtest at www.mybroadbandspeed.co.uk rather than wait the hour, that should give an indication of whether it's improved or not.
carolej
Re: WTH!
Date Download Speed Upload Speed
Today 21:52 2243 kbps (280kB/s) 184 kbps (23kB/s)
Thank you for the reimbursement offered also.
Chris
Legend
Fixes: 169
Re: WTH!
That's looking a bit more usable! Hopefully you won't need to connect to your neighbours wireless again.
carolej
Re: WTH!
You aren't the only one, fingers crossed!
