Power usage
Skippy70
Power usage
I wonder if anyone can give me any information about the difference in electricity usage between the Open Reach modem & Technicolor TG582n FTTC router that I am currently using & that of the PlusNet Hub One modem router that Plusnet supply now.
11 REPLIES 11
RealAleMadrid
Aspiring Hero
Fixes: 59
Re: Power usage
Not worth worrying about!
SpendLessTime
Fixes: 86
Re: Power usage
@Skippy70
If you really want to know more then this article will help  http://www.ispreview.co.uk/index.php/2017/01/energy-usage-uk-home-broadband-routers-big-isps-compare... but the amount used per year is negligible
Skippy70
Re: Power usage
tbh i had never even thought about it till i had these smart meters installed the damn thing has made me paranoid wish i had never let them put them in lol
PeterLoftus
Fixes: 5
Re: Power usage
@Skippy70 have you read that smart meters have a relay in them so the electricity company can cut you off remotely. https://www.nickhunn.com/when-smart-meters-get-hacked/
That should make you paranoid Undecided
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Skippy70
Re: Power usage
its pay as u go so that shouldnt be a problem.
PeterLoftus
Fixes: 5
Re: Power usage
@Skippy70 it's why I'm not having one and the difficulty in changing suppliers with the current meters being installed
SpendLessTime
Fixes: 86
Re: Power usage
@Skippy70
Biggest users for energy are (in rough order)
  1. Heating
  2. Hot Water
  3. Cooking
  4. Electric Power showers
  5. Tumble Dryers
  6. Washing Machine
  7. Fridges and/or freezers
  8. Gaming PC's Old TVs
  9. TV
  10. PC
  11. laptops
  12. set top box
  13. phones and tablets
  14. routers
The top 7 are the biggest ones and those are the ones you may want  to look at to see a meaningful reduction in your bills.
Skippy70
Re: Power usage
thanks for the information its very much appreciated,I have sort of solved my slight paranoia by turning of that damn screen so I am not seeing it all the time its worked wonders out of sight out of mind Wink lol
PeterLoftus
Fixes: 5
Re: Power usage
http://www.thegwpf.com/another-green-fiasco-millions-of-smart-meters-going-dumb/
Confirmation of by I'm not having a smart meter Cool_smiley
dfunked
Re: Power usage
@SpendLessTime
Not to forget lighting... Replaced a 300w halogen security light with a 10w LED one and noticed an immediate difference on our bills in the winter.
SpendLessTime
Fixes: 86
Re: Power usage
@dfunked
If it is a 300W light, then I would call that HEATING Wink
But point taken and I'll edit the list.
Edit: But I cannot as it has been too long since the original post. Sad
