Plusnet Hub 2 - https non-responsive
Fixes: 254
Has anyone else seen the Hub Two go non-responsive on port 443 ... whilst Port 80 remains responsive though redirecting to https://?
Browser reports "ERR_CONNECTION_RESET" - cURL diagnostic as below...
PS C:\Users\*****> curl.exe -v https://192.168.1.254
*   Trying 192.168.1.254:443...
* schannel: disabled automatic use of client certificate
* schannel: using IP address, SNI is not supported by OS.
* ALPN: curl offers http/1.1
* Recv failure: Connection was reset
* schannel: failed to receive handshake, SSL/TLS connection failed
* closing connection #0
curl: (35) Recv failure: Connection was reset
PS C:\Users\*****> curl.exe -v http://192.168.1.254
*   Trying 192.168.1.254:80...
* Established connection to 192.168.1.254 (192.168.1.254 port 80) from 192.168.1.34 port 49789
* using HTTP/1.x
> GET / HTTP/1.1
> Host: 192.168.1.254
> User-Agent: curl/8.23.0
> Accept: */*
* Request completely sent off
* HTTP 1.0, assume close after body
< HTTP/1.0 302 Found
< Server: httpd
< Date: Mon, 23 Nov 2026 00:50:08 GMT
< Location: /forced_https.htm
< Pragma: no-cache
< Cache-Control: no-cache,no-store,must-revalidate, post-check=0,pre-check=0
< Expires: 0
< Set-Cookie: urn=1ab849c822434d04; Path=/; HttpOnly
< CONTENT-LANGUAGE: en
< X-Frame-Options: DENY
< Connection: close
* shutting down connection #0
6 REPLIES 6
Re: Plusnet Hub 2 - https non-responsive
@Townman
There is a current thread Can't access hub manager on this very topic, without the curl diagnostics
I do not use my Hub two for daily use, it is connected to a local PPPoE server. I have seen this issue myself.
I note a netstat provides this result during the issue (windows or linux)
$ netstat -anto |grep 254:443
tcp        0      0 192.168.1.64:50540      192.168.1.254:443       FIN_WAIT2   timewait (11.68/0/0)
tcp        0      0 192.168.1.64:60302      192.168.1.254:443       FIN_WAIT2   timewait (57.83/0/0)
I find a second PC cannot connect to the Hub GUI either, there is no other option other than to switch the Hub off for a couple of minutes.
I do note that the router functions are still working, just not possible to manage the Hub.
A theory could be the Hub's web management service dropping HTTP/HTTPS sessions correctly. Over time it exhausts an internal resource and stops responding to GUI requests, while the routing side of the router continues to work normally. The FIN_WAIT_2 connections seen on clients are consistent with the Hub not completing TCP session shutdowns properly. A reboot clears the condition and restores access.
An observation when using the GUI I see this
tcp        0      0 192.168.1.64:41074      192.168.1.254:443       TIME_WAIT   timewait (10.46/0/0)
tcp        0      0 192.168.1.64:58764      192.168.1.254:443       TIME_WAIT   timewait (45.66/0/0)
tcp        0      0 192.168.1.64:42508      192.168.1.254:443       TIME_WAIT   timewait (35.31/0/0)
tcp        0      0 192.168.1.64:50476      192.168.1.254:443       TIME_WAIT   timewait (6.32/0/0)
tcp        0      0 192.168.1.64:58260      192.168.1.254:443       TIME_WAIT   timewait (29.10/0/0)
tcp        0      0 192.168.1.64:42478      192.168.1.254:443       TIME_WAIT   timewait (31.17/0/0)
tcp        0      0 192.168.1.64:41118      192.168.1.254:443       TIME_WAIT   timewait (14.61/0/0)
tcp        0      0 192.168.1.64:58232      192.168.1.254:443       TIME_WAIT   timewait (24.96/0/0)
tcp        0      0 192.168.1.64:50504      192.168.1.254:443       TIME_WAIT   timewait (8.39/0/0)
tcp        0      0 192.168.1.64:50470      192.168.1.254:443       TIME_WAIT   timewait (4.25/0/0)
tcp        0      0 192.168.1.64:58726      192.168.1.254:443       TIME_WAIT   timewait (41.52/0/0)
tcp        0      0 192.168.1.64:42496      192.168.1.254:443       TIME_WAIT   timewait (33.24/0/0)
tcp        0      0 192.168.1.64:50446      192.168.1.254:443       TIME_WAIT   timewait (2.18/0/0)
tcp        0      0 192.168.1.64:58792      192.168.1.254:443       TIME_WAIT   timewait (47.73/0/0)
tcp        0      0 192.168.1.64:58508      192.168.1.254:443       TIME_WAIT   timewait (49.80/0/0)
Fixes: 1,495
All normal here and the router has been up for 220 days.
Fixes: 254
That is my usual experience for similar long periods of continuous operation.  This is a new experience … and the up time is not long as there was a power outage last week.
Not that it is relevant to the issue, that outage took out one of my laptop power bricks... !!
@dvorak
Are you Fibre or Full Fibre?
I know @Townman is now
Fixes: 1,495
Full fibre
dleholt
My Hub Two had been dog slow since this firmware update. Sometimes it’d take a minute plus to load up the router pages. My sync speed had also dropped from ~23Mbps to ~15Mbps (I am miles from the cabinet on FTTC), though speed tests wouldn’t even get anywhere near that. Last week I set up a ThinkBroadband ping monitor which was regularly showing periods of packet loss of 10%, sometimes up to 20%.
All in all I was pretty fed up so today I rang Customer Support who suggested a factory reset of the Hub Two. I was sceptical but lo and behold, my sync speed is back up and the router’s own web server is pretty responsive again now.
Time will tell if this has solved all my issues, but if anyone is suffering similar, perhaps try a hard reset (with a pin in the reset hole on the back). Backup your settings first, reset the router, connect to it using its default WiFi/admin passwords from the card on the back, then restore your settings. You never know, that might make a deal of difference.
