How is Hub Two configured ?
FIXED- Subscribe to RSS Feed
- My Router
- How is Hub Two configured ?
46 minutes ago
Just curious about this before I plug it in...
I'm sent a Hub Two. The assumption is that I take it out of the box, plug it in and it will "just work"™.
I'm wondering how that works, is it pre-configured with my password before being shipped or does it somehow auto-configure when connected?
I have one, unused still in box. I have changed my password since receiving it. I plan to hook it up as a backup in case of problems with my main gear - just wondering how config works before I do that.
Fixed! Go to the fix.
Re: How is Hub Two configured ?
37 minutes ago
It is preconfigured, and will pick up your details via TR069 on first connection.
36 minutes ago
It does, The serial no of the router is registered to your account on dispatch. It initially connects using a standard username and then automatically configures to your account using the management platform
If it hasn't been used for some time, it MAY have dropped off the management platform and so may no longer auto-configure
31 minutes ago
Thanks, so it uses TR069 to configure. I guessed that would be it. I'll give it a try. I only got it about a month ago as "insurance" with my fttp install. I don't intend to use it but will keep it accessible to use if I ever need to test without "my equipment" confusing the picture.
It's also there for other family to use in the event of my demise; they won't care about my specialised setup.
