Plusnet Hub 2 - https non-responsive
- My Router
- Re: Plusnet Hub 2 - https non-responsive
15 hours ago - last edited 15 hours ago
Has anyone else seen the Hub Two go non-responsive on port 443 ... whilst Port 80 remains responsive though redirecting to https://?
Browser reports "ERR_CONNECTION_RESET" - cURL diagnostic as below...
PS C:\Users\*****> curl.exe -v https://192.168.1.254
* Trying 192.168.1.254:443...
* schannel: disabled automatic use of client certificate
* schannel: using IP address, SNI is not supported by OS.
* ALPN: curl offers http/1.1
* Recv failure: Connection was reset
* schannel: failed to receive handshake, SSL/TLS connection failed
* closing connection #0
curl: (35) Recv failure: Connection was reset
PS C:\Users\*****> curl.exe -v http://192.168.1.254
* Trying 192.168.1.254:80...
* Established connection to 192.168.1.254 (192.168.1.254 port 80) from 192.168.1.34 port 49789
* using HTTP/1.x
> GET / HTTP/1.1
> Host: 192.168.1.254
> User-Agent: curl/8.23.0
> Accept: */*
* Request completely sent off
* HTTP 1.0, assume close after body
< HTTP/1.0 302 Found
< Server: httpd
< Date: Mon, 23 Nov 2026 00:50:08 GMT
< Location: /forced_https.htm
< Pragma: no-cache
< Cache-Control: no-cache,no-store,must-revalidate, post-check=0,pre-check=0
< Expires: 0
< Set-Cookie: urn=1ab849c822434d04; Path=/; HttpOnly
< CONTENT-LANGUAGE: en
< X-Frame-Options: DENY
< Connection: close
* shutting down connection #0
7 hours ago - last edited 7 hours ago
There is a current thread Can't access hub manager on this very topic, without the curl diagnostics
I do not use my Hub two for daily use, it is connected to a local PPPoE server. I have seen this issue myself.
I note a netstat provides this result during the issue (windows or linux)
$ netstat -anto |grep 254:443
tcp 0 0 192.168.1.64:50540 192.168.1.254:443 FIN_WAIT2 timewait (11.68/0/0)
tcp 0 0 192.168.1.64:60302 192.168.1.254:443 FIN_WAIT2 timewait (57.83/0/0)
I find a second PC cannot connect to the Hub GUI either, there is no other option other than to switch the Hub off for a couple of minutes.
I do note that the router functions are still working, just not possible to manage the Hub.
An observation when using the GUI I see this
tcp 0 0 192.168.1.64:41074 192.168.1.254:443 TIME_WAIT timewait (10.46/0/0)
tcp 0 0 192.168.1.64:58764 192.168.1.254:443 TIME_WAIT timewait (45.66/0/0)
tcp 0 0 192.168.1.64:42508 192.168.1.254:443 TIME_WAIT timewait (35.31/0/0)
tcp 0 0 192.168.1.64:50476 192.168.1.254:443 TIME_WAIT timewait (6.32/0/0)
tcp 0 0 192.168.1.64:58260 192.168.1.254:443 TIME_WAIT timewait (29.10/0/0)
tcp 0 0 192.168.1.64:42478 192.168.1.254:443 TIME_WAIT timewait (31.17/0/0)
tcp 0 0 192.168.1.64:41118 192.168.1.254:443 TIME_WAIT timewait (14.61/0/0)
tcp 0 0 192.168.1.64:58232 192.168.1.254:443 TIME_WAIT timewait (24.96/0/0)
tcp 0 0 192.168.1.64:50504 192.168.1.254:443 TIME_WAIT timewait (8.39/0/0)
tcp 0 0 192.168.1.64:50470 192.168.1.254:443 TIME_WAIT timewait (4.25/0/0)
tcp 0 0 192.168.1.64:58726 192.168.1.254:443 TIME_WAIT timewait (41.52/0/0)
tcp 0 0 192.168.1.64:42496 192.168.1.254:443 TIME_WAIT timewait (33.24/0/0)
tcp 0 0 192.168.1.64:50446 192.168.1.254:443 TIME_WAIT timewait (2.18/0/0)
tcp 0 0 192.168.1.64:58792 192.168.1.254:443 TIME_WAIT timewait (47.73/0/0)
tcp 0 0 192.168.1.64:58508 192.168.1.254:443 TIME_WAIT timewait (49.80/0/0)
5 hours ago
4 hours ago - last edited 4 hours ago
That is my usual experience for similar long periods of continuous operation. This is a new experience … and the up time is not long as there was a power outage last week.
Not that it is relevant to the issue, that outage took out one of my laptop power bricks... !!
26 minutes ago
- My Router
