Plusnet Hub 2 - https non-responsive
Fixes: 253
Has anyone else seen the Hub Two go non-responsive on port 443 ... whilst Port 80 remains responsive though redirecting to https://?
Browser reports "ERR_CONNECTION_RESET" - cURL diagnostic as below...
PS C:\Users\*****> curl.exe -v https://192.168.1.254
*   Trying 192.168.1.254:443...
* schannel: disabled automatic use of client certificate
* schannel: using IP address, SNI is not supported by OS.
* ALPN: curl offers http/1.1
* Recv failure: Connection was reset
* schannel: failed to receive handshake, SSL/TLS connection failed
* closing connection #0
curl: (35) Recv failure: Connection was reset
PS C:\Users\*****> curl.exe -v http://192.168.1.254
*   Trying 192.168.1.254:80...
* Established connection to 192.168.1.254 (192.168.1.254 port 80) from 192.168.1.34 port 49789
* using HTTP/1.x
> GET / HTTP/1.1
> Host: 192.168.1.254
> User-Agent: curl/8.23.0
> Accept: */*
* Request completely sent off
* HTTP 1.0, assume close after body
< HTTP/1.0 302 Found
< Server: httpd
< Date: Mon, 23 Nov 2026 00:50:08 GMT
< Location: /forced_https.htm
< Pragma: no-cache
< Cache-Control: no-cache,no-store,must-revalidate, post-check=0,pre-check=0
< Expires: 0
< Set-Cookie: urn=1ab849c822434d04; Path=/; HttpOnly
< CONTENT-LANGUAGE: en
< X-Frame-Options: DENY
< Connection: close
* shutting down connection #0
3 REPLIES 3
Re: Plusnet Hub 2 - https non-responsive
@Townman
There is a current thread Can't access hub manager on this very topic, without the curl diagnostics
I do not use my Hub two for daily use, it is connected to a local PPPoE server. I have seen this issue myself.
I note a netstat provides this result during the issue (windows or linux)
$ netstat -anto |grep 254:443
tcp        0      0 192.168.1.64:50540      192.168.1.254:443       FIN_WAIT2   timewait (11.68/0/0)
tcp        0      0 192.168.1.64:60302      192.168.1.254:443       FIN_WAIT2   timewait (57.83/0/0)
I find a second PC cannot connect to the Hub GUI either, there is no other option other than to switch the Hub off for a couple of minutes.
I do note that the router functions are still working, just not possible to manage the Hub.
A theory could be the Hub's web management service dropping HTTP/HTTPS sessions correctly. Over time it exhausts an internal resource and stops responding to GUI requests, while the routing side of the router continues to work normally. The FIN_WAIT_2 connections seen on clients are consistent with the Hub not completing TCP session shutdowns properly. A reboot clears the condition and restores access.
An observation when using the GUI I see this
tcp        0      0 192.168.1.64:41074      192.168.1.254:443       TIME_WAIT   timewait (10.46/0/0)
tcp        0      0 192.168.1.64:58764      192.168.1.254:443       TIME_WAIT   timewait (45.66/0/0)
tcp        0      0 192.168.1.64:42508      192.168.1.254:443       TIME_WAIT   timewait (35.31/0/0)
tcp        0      0 192.168.1.64:50476      192.168.1.254:443       TIME_WAIT   timewait (6.32/0/0)
tcp        0      0 192.168.1.64:58260      192.168.1.254:443       TIME_WAIT   timewait (29.10/0/0)
tcp        0      0 192.168.1.64:42478      192.168.1.254:443       TIME_WAIT   timewait (31.17/0/0)
tcp        0      0 192.168.1.64:41118      192.168.1.254:443       TIME_WAIT   timewait (14.61/0/0)
tcp        0      0 192.168.1.64:58232      192.168.1.254:443       TIME_WAIT   timewait (24.96/0/0)
tcp        0      0 192.168.1.64:50504      192.168.1.254:443       TIME_WAIT   timewait (8.39/0/0)
tcp        0      0 192.168.1.64:50470      192.168.1.254:443       TIME_WAIT   timewait (4.25/0/0)
tcp        0      0 192.168.1.64:58726      192.168.1.254:443       TIME_WAIT   timewait (41.52/0/0)
tcp        0      0 192.168.1.64:42496      192.168.1.254:443       TIME_WAIT   timewait (33.24/0/0)
tcp        0      0 192.168.1.64:50446      192.168.1.254:443       TIME_WAIT   timewait (2.18/0/0)
tcp        0      0 192.168.1.64:58792      192.168.1.254:443       TIME_WAIT   timewait (47.73/0/0)
tcp        0      0 192.168.1.64:58508      192.168.1.254:443       TIME_WAIT   timewait (49.80/0/0)
Fixes: 1,495
All normal here and the router has been up for 220 days.
Fixes: 253
That is my usual experience for similar long periods of continuous operation.  This is a new experience … and the up time is not long as there was a power outage last week.
Not that it is relevant to the issue, that outage took out one of my laptop power bricks... !!
