Cannot Login to account
B8K
Entered my username and password and it says incorrect details. I set these up when I opened the account. I haven't tried to login for months.
8 REPLIES 8
Fixes: 466
Re: Cannot Login to account
Moderator's Note
This topic has been moved from Home Phone to My Account/Billing
Fixes: 357
@B8K Are you sure you are entering the correct password? Does it contain any special characters? Are you entering a figure '0' for a letter O', or vice versa?
Fixes: 138
@B8K
Have you considered using the 'Forgotten your password' link found on the login screen?
I believe it will send an email to the registered email address for your account
Sometimes auto complete can add a space to the end of a word.
HTH
B8K
I did not use the link in my email to go to Plusnet. Instead I started with a fresh login and when it said reset password this time it worked. So I got in and accessed my billing. But it still says an error as it always has done. There is nothing processing but says there is. I can't see how to attach the screen grab here.
Fixes: 357
@B8K Is this error something along the lines of 'an error has occurred, you already have change in progress' across your account main page?
B8K
Sort of...saying I have a phone order in progress
Fixes: 357
OK - this is a known, but unacknowledged, error in the accounting system - this message should clear on completion of an order, but fails to do so. Your best bet is to call in and ask for the error to be manually rectified.
B8K
OK....What a drag! Inadequate number of software engineers keeping the account system working well? No need to reply....
