Vista Firewall
Vista Firewall
Vista Firewall
The Firewall should be on by default, but to ensure your computer is secure you may want to double check it.
  1. Click Start and Control Panel
  2. control_panel
    Control Panel
  3. Click on Check this computer's security status.
    firewall4
    Control Panel > Check Security Status
  4. You can now see if Windows Firewall is protecting your computer. If it is not protecting your system, turn it on.
    firewall2
    Windows Security Centre > Firewall settings
  5. Turn on or off the Firewall by clicking on the Firewall bar and selecting to Turn the Firewall on or off. We recommend that you turn the firewall on, unless you are troubleshooting connection problems or have installed an alternate firewall program. See our Guide to Security Software.
    firewall5
    Windows Security Centre > Firewall on / off
[Top]
0 Comments
