7 Steps To Securing Your Wireless Home Network
With a few changes to your settings you can make your home wireless network more secure. Here we'll show you 7 of our most recommended tips.
Most of these only take a minute or two to do and using all, or a combination of them, you'll give your home network the best possible protection.
  1. Switch on encryption
  2. Change your SSID name
  3. Switch off SSID broadcast
  4. Switch on MAC filtering
  5. Change the password for web access
  6. Switch your network off if you're not using it for long periods
  7. Put your router or access point in a safe place
Encryption scrambles messages sent over wireless networks, making them harder for people to read. Most routers now come with encryption built-in as standard. However, you should check the settings as this is usually set to WEP (Wired Equivalent Protection). We recommend not leaving your wireless router settings like this. This is because WEP is now an old wireless encryption standard, so it doesn't offer the same advanced protection as WPA or WPA2. Because of this it can be hacked into really easily!
Ideally you should enable either WPA-PSK (Wi-Fi Protected Access, also known as WPA- Personal) or WPA2 wireless encryption, if you haven't already done this.
WPA-PSK should really be the very least amount of security you apply to your network. To be even more secure use WPA2 (if your wireless router and wireless adaptor both support this). WPA2 is the latest wireless encryption standard and offers the maximum amount of encryption.
Do:
  • Change your wireless encryption key every month.
Don't:
  • Connect to unprotected wireless networks. Your usage can be monitored and a hacker can gain access your network.
  • Connect to an unprotected wireless network that asks you for a password, unless the site is encrypted. (If it is it'll have a lock symbol in the bottom right-hand corner of the screen)
The SSID (Service Set Identifier) means the name of your wireless connection (you'll see this on the list of available wireless connections when you're going online).
You might think it's handy to call your home wireless network 'My home network', or something similar to identify it as yours. However, this will make it obvious to anyone else searching for available wireless connections what your network is.
Changing the name of the wireless connection to something else can put a potential hacker off. This is because they'll see you've made some effort to secure your wireless network.
Here's a few things to think about:
Do:
  • Choose a SSID name which is made up of letters and numbers.
  • Make the name as long as the maximum length allowed.
  • Change the name every few months.
Don't:
  • Use your name, date of birth, home address or other personal piece of information.
  • Re-use a name that you've used elsewhere (e.g. for a password).
  • Make your network more tempting by naming it 'Keep Out' or 'Top Secret'. It'll only make a hacker even more curious!
Your SSID will be broadcast by your router or the wireless access point at regular periods. By disabling SSID broadcast you'll be making your wireless connection invisible to anyone in the area who's searching for a wireless network. This means they won't be able to log in and 'piggy back' your wireless connection. Most wireless routers come pre-configured with a 'factory default' SSID.
To disable SSID broadcast, simply go into your router's settings and uncheck the option that lets the name be broadcast. You will need to setup any new client manually, as autoscanning won't work.
Each device on a network has a unique code that identifies it, known as a Physical Address or MAC (Media Access Control) Address. Our next suggestion is to only allow wireless devices that you know and trust to get access to your network.
To set up MAC filtering first of all you need to know your MAC address
For Microsoft Windows
Step 1- Find out your MAC address:
  1. Click Start
  2. Click Run
  3. Then type cmd in the Run box
  4. Now type ipconfig /all
  5. Look at Physical Address - that's the MAC address.
Step 2 - Setup MAC filtering:
Now you'll need to check the instruction manual that came with your router to see how to setup MAC filtering.
For Apple Mac
  1. Click the Apple menu in the top left of the screen.
  2. Click on About this Mac.
  3. Click on More Info once the dialogue box has opened.
  4. Look under the Networks section. You'll find your MAC address at the botton of the list.
The manufacturer of your router should provide a web page which will allow you to setup your hardware.
These web access pages are protected by a login screen, but often the default login details are basic and well known to hackers. Because of this you should change the default password to something stronger.
Do:
  • Choose a web access name which is made up of upper and lowercase letters, numbers and special characters.
Don't
  • Keep the default web access password. It's easy to guess.
  • Use personal information, such as your name or date of birth
Going away on holiday, or know that you're going to be offline for a while? It's a good idea to shut your network down. Leaving yours on is like leaving your house door unlocked whilst you're out.
If you're only using the wired connections on your wireless router you can sometimes turn off Wi-Fi, without shutting down the whole of your network.
Did you know that your wireless signal is not only available inside your house, but also outside it too? A small amount of 'leakage' is fine, but the further the wireless signal reaches the greater the chance that your wireless network will be seen by others and a greater chance that attempted logins are made. Wireless signals can stretch to your neighbour's homes, or even as far as different streets.
Where you put your router or access point in your home makes a difference to how far your wireless signal reaches.
Do:
  • Put your router or access point near the centre of your home.
Don't:
  • Put your router or access point near windows. This will 'leak' your wireless signal outdoors.
0 Comments
