How to set up an additional mailbox on a Blackberry
To set up a Plusnet account on a blackberry you need to do the following :
Set up
Locate the set up icon as above.
E-mail settings
Then go to e-mail settings.
Add
Choose add  as above then other
Other
Email address
Type in your e-mail address and password, click next.
Provide settings
If this is an additional mailbox it will fail as the blackberry attempts to log into it.
Choose I will provide settings.
Pop/IMAP
Choose POP/IMAP again ensure e-mail address is typed in
Further down the screen will be email server and username.
Server/username
For your additional mail box you need to type in the account username then a + symbol
So for example if  your username was  joebloggs the main mailbox username is simply joebloggs.  However if you create an additional mailbox  e.g mail, making your e-mail address  [email protected] then the username here would be joebloggs+mail
Choose Next
UntitledOnce completed you should see the screen above
Now you will be able to receive e-mails, and your Plusnet account will be shown as a small "earth" globe on the front screen.
2 Comments
