Crackling On The Line
thekunig
Hi I have used your troubleshooter - Line test comes back ok - have connected directly into the master socket - removed Now tv box and changed filters - I also have bought a new home phone - but there is still crackling on the line but Broadband Speeds seem ok ? - Any ideas
14 REPLIES 14
CJT-80
Fixes: 4
Re: Crackling On The Line
@thekunig
Can you access the test socket?
Plug new phone in to test socket, and dial 17070 select option for "Quiet Line Test" if not quiet report as a noisy line.
Kind Regards,
CJT
thekunig
I dont have a test socket as both are old NTE4 and not NTE5 ?
Mads
Fixes: 79
Hey @thekunig
You should be able to find the test socket once you unscrew the face plate, it'll be behind that. I've now booked in an engineer appointment for you, you can find all info on this ticket here.
Thanks.
198kHz
Fixes: 41
There is no NTE4.
For clarity - if you a socket like this
then there is no test socket, but if you have one like this
you can access the test socket as advised by @Mads
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
thekunig
Like I mentioned prior the socket is the first one with no test socket?
198kHz
Fixes: 41
@thekunig OK, that's what I'd inferred from your initial post, but I just wanted to clarify as @Mads seemed to have assumed otherwise.
thekunig
So despite being told I have an engineers appointment today between 08:00 and 13:00 - They never showed !!
Mads
Fixes: 79
I'm sincerely sorry to hear this @thekunig
I've re-arranged an engineer appointment for 22/06 between 8-1pm for you. I've also taken ownership of this and will be checking in with you on Tuesday to make sure the appointment went ahead and to update you on engineer notes and the next steps.
Thanks.
MMG
With the older socket with no faceplate, have you tried removing the faceplate and disconnecting any extension cables behind it - if there are any connected. Some may require extension sockets to be plugged into the front, but I am sure that some of them do have an extension connections at the back.
Then connecting your phone into the front and dialing the number previously mentioned to get the silence test?
thekunig
I think you need to cancel that as I have just switched.- See ticket
thekunig
@ MMG  = Thanks for your help - buy I'm outa here - never got anywhere near my speeds promised for months and this was the lasy straw - cheers
MMG
Dont be too hard on Plusnet as they use BT Openreach infrastructure to connect to their network. Assuming that they had booked the engineer, (which I assuming they would have had done) it's not their fault if the engineer never showed, its BT Openreach.
MMG
Its certainly frustrating when your in limbo and have to rely on third parties to resolve things.
But you may have the same issue with another provider. Remember BT dont own the infrastructure anymore as BT Openreach are a seperate company.
Mads
Fixes: 79
Thanks for getting back to me @thekunig, I'm sorry you've arranged a transfer of providers. I've cancelled the engineer appointment for you now.
Thanks and take care.
