Suddenly capped at 30Mb/s
- Re: Suddenly capped at 30Mb/s
15-11-2014 1:39 AM
Hi All,
I've had a stable connection for the majority of the last 18months on Unlimited Fibre, but today I seem to be capped at 30Mb/s (using torrents or speedtest) and Upload (Usually sync at 74/20)
Gateway pcl-bng04 and pcl-bng02 both give the same cap at exact 30Mb/s when speed tests etc.
BT wholesale test:
Download Speed 29.58 Mbps / 51.36 Mbps Max Achievable Speed
What gives?
BT wholesale test:
What gives?
Message 1 of 8
(1,310 Views)
7 REPLIES 7
15-11-2014 7:16 AM
HI
Check the current line speed here.
If it's dropped ask PN to put it back. If not raise a speed fault and see if that helps.
Message 2 of 8
(667 Views)
17-11-2014 12:03 PM
Can you give us the full results of a BT Wholesale speedtest after you've run the 'further diagnostics' section please.
Message 3 of 8
(667 Views)
17-11-2014 6:49 PM
Quote from: petecov44 HI
Thanks it had dropped to 38 and Plusnet tech updated to 78 again.
Message 4 of 8
(667 Views)
17-11-2014 6:51 PM
Quote from: Chris Can you give us the full results of a BT Wholesale speedtest after you've run the 'further diagnostics' section please.
Hi Chris,
Although the speed was increased to 78 on my profile, the BT one is still showing as 50.. anyway to change this back to 77ish?
Full speed test results taken today:
http://s26.postimg.org/4aooquz3t/btwholesale.png
Message 5 of 8
(667 Views)
17-11-2014 6:59 PM
That speedtest is odd!
The IP profile on there is showing as 38.72Mb, but you've managed to achieve 12Mb faster than it should allow you to.
We have no control on the IP profile showing on a speedtest, this is controlled by the DLM (Dynamic Line Management) equipment. The link here explains how and why it's there: http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/
Message 6 of 8
(667 Views)
17-11-2014 8:52 PM
So to get speed raised again, according to that article, I wait hoping the line is stable for 8-24 days.
Message 7 of 8
(667 Views)
19-11-2014 11:29 AM
Message 8 of 8
(667 Views)
