Suddenly capped at 30Mb/s
somebloke
Hi All,
I've had a stable connection for the majority of the last 18months on Unlimited Fibre, but today I seem to be capped at 30Mb/s (using torrents or speedtest) and Upload  (Usually sync at 74/20)
Gateway pcl-bng04 and  pcl-bng02 both give the same cap at exact 30Mb/s when speed tests etc.
BT wholesale test:
Download Speed  29.58 Mbps / 51.36 Mbps Max Achievable Speed
What gives?  Roll_eyes
7 REPLIES 7
petecov44
Re: Suddenly capped at 30Mb/s
HI
Check the current line speed here.
If it's dropped ask PN to put it back. If not raise a speed fault and see if that helps.
Fixes: 168
Can you give us the full results of a BT Wholesale speedtest after you've run the 'further diagnostics' section please.
 Chris Parr
 Plusnet Staff
somebloke
Quote from: petecov44
HI
Thanks it had dropped to 38 and Plusnet tech updated to 78 again.
somebloke
Quote from: Chris
Hi Chris,
Although the speed was increased to 78 on my profile, the BT one is still showing as 50..  anyway to change this back to 77ish?
Full speed test results taken today:
http://s26.postimg.org/4aooquz3t/btwholesale.png
Fixes: 168
That speedtest is odd!
The IP profile on there is showing as 38.72Mb, but you've managed to achieve 12Mb faster than it should allow you to.
We have no control on the IP profile showing on a speedtest, this is controlled by the DLM (Dynamic Line Management) equipment. The link here explains how and why it's there: http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/
 Chris Parr
 Plusnet Staff
somebloke
So to get speed raised again, according to that article, I wait  hoping the line is stable for 8-24 days.
Undecided
somebloke
Quote from: somebloke
In the end I did not need to wait 8-24 days a techy at plusnet changed something on my profile and said it should now "stick".
Well I'm back to normal now, for now.  Cheesy
