Plusnet fibre broadband does not cope with uploads and will disconnect you...
jamesmcmahon88
Re: Plusnet fibre broadband does not cope with uploads and will disconnect you...
@bobpullen I also have this same issue since moving to PlusNet and it is affecting my work. Can you please send my router the latest firmware to resolve the issue.
Plusnet Hub One | Software version 4.7.5.1.83.8.226 | Last updated Unknown
john78
Well, after 2 months I still get daily deconnexions, and it systematically breaks on higher upload traffic. Not what I would call a high quality of broadband service... Let's hope it gets better soon,
ralframone
Hello @bobpullen I have the drop out problem
3. Firmware version: Software version 4.7.5.1.83.8.226 Last updated Unknown
What details do you need from me to get a firmware upgrade?
Thank you
CrustyManMeat
I have been having these problems since JULY and its getting worse by the week. My laptop and Xbox keep dropping connection and now its interfering with my website. This is ridiculous.
Chris
Legend
Fixes: 169
Checking your line, you don't seem to be impacted by the issues discussed in this thread as the number of disconnections on your line is very low. If your devices are dropping the internal wifi signal, this is not the same as being discussed and I'd advise opening your own thread regarding this for support.
ralframone
My firmware updated yesterday evening and so far have stayed connected. Yay!
jamesmcmahon88
@ralframone did you do anything for it to appear? I haven't got it yet.
danbeddows
Hi Chris
I'm having frequent disconnects too. I've only had 5-6 over the past week, but have had this happen for a few months.
Is there any chance you take a look?
Cheers,
Dan
bluewhale
@danbeddows out of interest are people using the hub one modem or using it connected to the openreach modem
and what snr value are you on?
danbeddows
I’m using the hub one modem. I only use it the modem and have a Time Capsule to handle wireless.
SNR values:
SNR Margin Down=3.0dB, Up=7.4dB
bluewhale
@danbeddows do you have access to an openreach modem, i'm now using one of them flashed to unlock it's gui etc, finding it more stable. would be interested if you find the same.
danbeddows
@bluewhale unfortunately I don't have access to another modem, this is the only one I have.
@bobpullen is there any chance you could take a look? ^
Thanks!
Dan
bobpullen
Fixes: 316
Sorry for the lack of replies folks, been a bit hectic of late! I'll try my best to take a look tomorrow when I'm back in the office.
danbeddows
No worries @bobpullen. If you get a minute that would be great - the line has just been dropped twice in 10 minutes.
danbeddows
And again just now...
