Plusnet fibre broadband does not cope with uploads and will disconnect you...
- Re: Plusnet fibre broadband does not cope with upl...
Re: Plusnet fibre broadband does not cope with uploads and will disconnect you...
10-11-2017 2:06 PM
@bobpullen I also have this same issue since moving to PlusNet and it is affecting my work. Can you please send my router the latest firmware to resolve the issue.
Plusnet Hub One | Software version 4.7.5.1.83.8.226 | Last updated Unknown
10-11-2017 9:55 PM
Well, after 2 months I still get daily deconnexions, and it systematically breaks on higher upload traffic. Not what I would call a high quality of broadband service... Let's hope it gets better soon,
13-11-2017 11:51 PM
Hello @bobpullen I have the drop out problem
3. Firmware version: | Software version 4.7.5.1.83.8.226 Last updated Unknown |
What details do you need from me to get a firmware upgrade?
Thank you
15-11-2017 9:09 AM
I have been having these problems since JULY and its getting worse by the week. My laptop and Xbox keep dropping connection and now its interfering with my website. This is ridiculous.
15-11-2017 1:32 PM
Checking your line, you don't seem to be impacted by the issues discussed in this thread as the number of disconnections on your line is very low. If your devices are dropping the internal wifi signal, this is not the same as being discussed and I'd advise opening your own thread regarding this for support.
15-11-2017 1:38 PM
My firmware updated yesterday evening and so far have stayed connected. Yay!
15-11-2017 4:51 PM
25-11-2017 4:48 PM
Hi Chris
I'm having frequent disconnects too. I've only had 5-6 over the past week, but have had this happen for a few months.
Is there any chance you take a look?
Cheers,
Dan
25-11-2017 9:50 PM
@danbeddows out of interest are people using the hub one modem or using it connected to the openreach modem
and what snr value are you on?
25-11-2017 10:34 PM
SNR values:
SNR Margin Down=3.0dB, Up=7.4dB
26-11-2017 12:15 AM
@danbeddows do you have access to an openreach modem, i'm now using one of them flashed to unlock it's gui etc, finding it more stable. would be interested if you find the same.
28-11-2017 10:01 AM
@bluewhale unfortunately I don't have access to another modem, this is the only one I have.
@bobpullen is there any chance you could take a look? ^
Thanks!
Dan
28-11-2017 9:04 PM
Sorry for the lack of replies folks, been a bit hectic of late! I'll try my best to take a look tomorrow when I'm back in the office.
04-12-2017 8:39 AM - edited 04-12-2017 8:39 AM
No worries @bobpullen. If you get a minute that would be great - the line has just been dropped twice in 10 minutes.
04-12-2017 9:41 AM
And again just now...
