Odd TBB test ?
rongtw
Fixes: 12
Re: Odd TBB test ?
Nice Christmas morning Sad  gateway pcn-bng02. Colindale Point of Presence.
Nothing Running . or downloading !!!!
Re: Odd TBB test ?
I am getting the same type of result as yourself @rongtw but I'm connected to gateway psb-bng03, in Southbank.
Southbank
SteveA
Re: Odd TBB test ?
Merry Christmas... no surprise presents from Santa
148265657892670036561
pcn-bng04. This is located in Colindale Point of Presence.
rongtw
Fixes: 12
Re: Odd TBB test ?
I must have been Naughty this year Cheesy
gateway psb-bng03. after power off my router Like @Anonymous
Re: Odd TBB test ?
Well I've just hopped interfaces on my router and I am now connected to gateway pcn-bng01, in Colindale and this is the result using Chrome and its flash due to the issue reported on TBB regarding FF, Opera et al.
Colindale
However, using the HTML5 (I think) speed test again using Chrome I get this!
HTML5 Test!
But using fast.com I get this:
Fast
MrSilver
Fixes: 9
Re: Odd TBB test ?
What would really help is not jsut isolated one off tests - we are way beyond proving there is an issue, what we need to try to do now is narrow down more where the specific issue is!
If you have a windows PC just follow the instructions in this post, and then PM me the results, and I can add to a single graph, I think its either certain BNGs or Soutbank that has the problem, I can only test so many at once. All morning I have been hammering PCN-BNG02 with no issues, now onto PSB-BNG01
https://community.plus.net/t5/Fibre-Broadband/Odd-TBB-test/m-p/1398901#M53035
if you have linux then look a few more posts/pages up for linux scripts
Last 2 days I've downloaded over 200GB, hop there is no fair use policy about to hit me 🙂
SpendLessTime
Fixes: 86
Re: Odd TBB test ?
Definitely not location based as I and others have the same issues at Colindale.
I tried your test on Windows and killed it on the 4th loop through. The first 3 downloads ran at full  speed reporting download in 10M+ and the the 4th one fell through the floor reporting 50K. I killed the test because a) it showed really quickly that the issue is real and b) the thought of hammering my SSD gave me grave doubts about letting it run all day.
I think Plusnet have sufficient info to be able to replicate this issue and that further testing is just a waste. They know which gateways we are reporting faults against, our IP's, the routes that they send our traffic through and just doing the same tests is now wasteful.
MrSilver
Fixes: 9
Re: Odd TBB test ?
Hi
Running big through the day helps see if your 50k slow always runs at 50k or if you get variable speeds. Thanks for running the test though, can you
Confirm which gateway please.
Btw don't worry about sd writes, back using 2012 tech tomshardware worked out you would have to be writing 5gig data a day for 5 years to get near its lifespan. If you have anything in the last couple of years you need to be running a ssd in a data centre with near constant read writes for a long time.
Most modern ssds have a drive write per day of over 1, meaning they can do 100gig per day for their 3-5 year warranty.
Also if it is something you are worried about run performance monitor on windows and checkout how many things are read writing to the disk when you aren't using the computer, lots of background services to shutdown if you want to prolong further.
SteveA
Re: Odd TBB test ?
I sort of agree with @SpendLessTime - we've given PN enough to work on : we've proven without doubt that there is a problem with their new infrastructure and it seems to occur on multiple gateways in both locations. I'd expect PN to have used a standardised configuration for all the hardware so the problem (if it is configuration related ) would appear on all gateways.
What I want from PN is for them to admit there is a problem and start investigating the problem and work out how they are going to fix it.
If PN need us to do more specific tests then they should ask us.
rongtw
Fixes: 12
Re: Odd TBB test ?
PN will not admit they have a problem , Because they say its the same for other ISP,s,,, But other ISP,s have fixed the problem .
PN seam to be unwilling to fix it here
SpendLessTime
Fixes: 86
Re: Odd TBB test ?
@MrSilver
pcn-bng04.plus.net (84.93.253.94)
You are currently connected to gateway pcn-bng04.
http://users.plus.net/@gateway_custom?debug-ip=yes
 Just ran the test for a few minutes, This is the first bad speed on the 4th attempt then the next started the same way too.
Good times
2016-12-26 14:36:41 (8.10 MB/s) - '20MB.zip' saved [20971520/20971520]
2016-12-26 14:36:44 (8.63 MB/s) - '20MB.zip' saved [20971520/20971520]
2016-12-26 14:36:46 (9.04 MB/s) - '20MB.zip' saved [20971520/20971520]
--2016-12-26 14:36:48-- http://http-speedtest4.thinkbroadband.com/20MB.zip
Resolving http-speedtest4.thinkbroadband.com (http-speedtest4.thinkbroadband.com)... 80.249.103.8
Connecting to http-speedtest4.thinkbroadband.com (http-speedtest4.thinkbroadband.com)|80.249.103.8|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 20971520 (20M) [application/zip]
Saving to: '20MB.zip'
0K .......... .......... .......... .......... .......... 0% 1.16M 17s
50K .......... .......... .......... .......... .......... 0% 720K 23s
100K .......... .......... .......... .......... .......... 0% 33.0K 3m40s
150K .......... .......... .......... .......... .......... 0% 147K 3m19s
200K .......... .......... .......... .......... .......... 1% 247K 2m55s
250K .......... .......... .......... .......... .......... 1% 734K 2m30s
300K .......... .......... .......... .......... .......... 1% 661K 2m13s
350K .......... .......... .......... .......... .......... 1% 129K 2m15s
400K .......... .......... .......... .......... .......... 2% 72.1K 2m31s
450K .......... .......... .......... .......... .......... 2% 174K 2m27s
500K .......... .......... .......... .......... .......... 2% 514K 2m17s
550K .......... .......... .......... .......... .......... 2% 761K 2m7s
600K .......... .......... .......... .......... .......... 3% 172K 2m6s
650K .......... .......... .......... .......... .......... 3% 63.1K 2m19s
700K .......... .......... .......... .......... .......... 3% 253K 2m15s
750K .......... .......... .......... .......... .......... 3% 375K 2m9s
800K .......... .......... .......... .......... .......... 4% 542K 2m4s
850K .......... .......... .......... .......... .......... 4% 173K 2m3s
900K .......... .......... .......... .......... .......... 4% 101K 2m6s
950K .......... .......... .......... .......... .......... 4% 31.6K 2m30s
1000K .......... .......... .......... .......... .......... 5% 75.2K 2m35s
1050K .......... .......... .......... .......... .......... 5% 67.6K 2m41s
1100K .......... .......... .......... .......... .......... 5% 365K 2m36s
1150K .......... .......... .......... .......... .......... 5% 47.2K 2m46s
1200K .......... .......... .......... .......... .......... 6% 613K 2m40s
1250K .......... .......... .......... .......... .......... 6% 175K 2m38s
1300K .......... .......... .......... .......... .......... 6% 547K 2m33s
1350K .......... .......... .......... .......... .......... 6% 147K 2m31s
1400K .......... .......... .......... .......... .......... 7% 601K 2m27s
1450K .......... .......... .......... .......... .......... 7% 980K 2m22s
1500K .......... .......... .......... .......... .......... 7% 486K 2m19s
1550K .......... .......... .......... .......... .......... 7% 166K 2m18s
1600K .......... .......... .......... .......... .......... 8% 251K 2m15s
1650K .......... .......... .......... .......... .......... 8% 139K 2m15s
1700K .......... .......... .......... .......... .......... 8% 64.2K 2m19s
1750K .......... .......... .......... .......... .......... 8% 383K 2m16s
1800K .......... .......... .......... .......... .......... 9% 135K 2m16s
1850K .......... .......... .......... .......... .......... 9% 367K 2m13s
1900K .......... .......... .......... .......... .......... 9% 70.5K 2m16s
1950K .......... .......... .......... .......... .......... 9% 66.6K 2m19s
2000K .......... .......... .......... .......... .......... 10% 8.35K 3m9s
2050K .......... .......... .......... .......... .......... 10% 631K 3m5s
2100K .......... .......... .......... .......... .......... 10% 87.5K 3m5s
2150K .......... .......... .......... .......... .......... 10% 106K 3m4s
2200K .......... .......... .......... .......... .......... 10% 175K 3m2s
2250K .......... .......... .......... .......... .......... 11% 564K 2m58s
2300K .......... .......... .......... .......... .......... 11% 371K 2m55s
2350K .......... .......... .......... .......... .......... 11% 171K 2m53s
2400K .......... .......... .......... .......... .......... 11% 45.8K 2m57s
2450K .......... .......... .......... .......... .......... 12% 18.8K 3m12s
2500K .......... .......... .......... .......... .......... 12% 472K 3m9s
2550K .......... .......... .......... .......... .......... 12% 513K 3m5s
2600K .......... .......... .......... .......... .......... 12% 141K 3m4s
2650K .......... .......... .......... .......... .......... 13% 345K 3m1s
2700K .......... .......... .......... .......... .......... 13% 604K 2m58s
2750K .......... .......... .......... .......... .......... 13% 15.9K 3m14s
2800K .......... .......... .......... .......... .......... 13% 537K 3m10s
2850K .......... .......... .......... .......... .......... 14% 60.1K 3m12s
2900K .......... .......... .......... .......... .......... 14% 179K 3m10s
2950K .......... .......... .......... .......... .......... 14% 687K 3m6s
3000K .......... .......... .......... .......... .......... 14% 64.2K 3m7s
3050K .......... .......... .......... .......... .......... 15% 716K 3m4s
3100K .......... .......... .......... .......... .......... 15% 436K 3m1s
3150K .......... .......... .......... .......... .......... 15% 535K 2m58s
3200K .......... .......... .......... .......... .......... 15% 179K 2m57s
3250K .......... .......... .......... .......... .......... 16% 68.4K 2m57s
3300K .......... .......... .......... .......... .......... 16% 453K 2m55s
3350K .......... .......... .......... .......... .......... 16% 15.7K 3m8s
3400K .......... .......... .......... .......... .......... 16% 725K 3m5s
3450K .......... .......... .......... .......... .......... 17% 449K 3m2s
3500K .......... .......... .......... .......... .......... 17% 681K 2m59s
3550K .......... .......... .......... .......... .......... 17% 603K 2m57s
3600K .......... .......... .......... .......... .......... 17% 531K 2m54s
3650K .......... .......... .......... .......... .......... 18% 539K 2m52s
3700K .......... .......... .......... .......... .......... 18% 143K 2m50s
3750K .......... .......... .......... .......... .......... 18% 588K 2m48s
3800K .......... .......... .......... .......... .......... 18% 174K 2m47s
3850K .......... .......... .......... .......... .......... 19% 374K 2m45s
3900K .......... .......... .......... .......... .......... 19% 15.7K 2m55s
3950K .......... .......... .......... .......... .......... 19% 173K 2m54s
4000K .......... .......... .......... .......... .......... 19% 575K 2m51s
4050K .......... .......... .......... .......... .......... 20% 402K 2m49s
4100K .......... .......... .......... .......... .......... 20% 729K 2m47s
4150K .......... .......... .......... .......... .......... 20% 885K 2m45s
4200K .......... .......... .......... .......... .......... 20% 167K 2m44s
4250K .......... .......... .......... .......... .......... 20% 292K 2m42s
4300K .......... .......... .......... .......... .......... 21% 481K 2m40s
4350K .......... .......... .......... .......... .......... 21% 407K 2m38s
4400K .......... .......... .......... .......... .......... 21% 633K 2m36s
4450K .......... .......... .......... .......... .......... 21% 53.1K 2m37s
4500K .......... .......... .......... .......... .......... 22% 177K 2m36s
4550K .......... .......... .......... .......... .......... 22% 600K 2m34s
4600K .......... .......... .......... .......... .......... 22% 172K 2m33s
4650K .......... .......... .......... .......... .......... 22% 179K 2m32s
4700K .......... .......... .......... .......... .......... 23% 160K 2m31s
4750K .......... .......... .......... .......... .......... 23% 136K 2m30s
4800K .......... .......... .......... .......... .......... 23% 171K 2m29s
4850K .......... .......... .......... .......... .......... 23% 536K 2m27s
4900K .......... .......... .......... .......... .......... 24% 385K 2m25s
4950K .......... .......... .......... .......... .......... 24% 168K 2m24s
5000K .......... .......... .......... .......... .......... 24% 419K 2m23s
5050K .......... .......... .......... .......... .......... 24% 667K 2m21s
5100K .......... .......... .......... .......... .......... 25% 131K 2m21s
5150K .......... .......... .......... .......... .......... 25% 201K 2m20s
5200K .......... .......... .......... .......... .......... 25% 597K 2m18s
5250K .......... .......... .......... .......... .......... 25% 174K 2m17s
5300K .......... .......... .......... .......... .......... 26% 719K 2m16s
5350K .......... .......... .......... .......... .......... 26% 134K 2m15s
5400K .......... .......... .......... .......... .......... 26% 170K 2m14s
5450K .......... .......... .......... .......... .......... 26% 169K 2m13s
5500K .......... .......... .......... .......... .......... 27% 65.8K 2m14s
5550K .......... .......... .......... .......... .......... 27% 15.4K 2m21s
5600K .......... .......... .......... .......... .......... 27% 63.4K 2m21s
5650K .......... .......... .......... .......... .......... 27% 567K 2m19s
5700K .......... .......... .......... .......... .......... 28% 466K 2m18s
5750K .......... .......... .......... .......... .......... 28% 142K 2m17s
5800K .......... .......... .......... .......... .......... 28% 88.7K 2m17s
5850K .......... .......... .......... .......... .......... 28% 639K 2m16s
5900K .......... .......... .......... .......... .......... 29% 513K 2m14s
5950K .......... .......... .......... .......... .......... 29% 168K 2m13s
6000K .......... .......... .......... .......... .......... 29% 606K 2m12s
6050K .......... .......... .......... .......... .......... 29% 374K 2m11s
6100K .......... .......... .......... .......... .......... 30% 149K 2m10s
6150K .......... .......... .......... .......... .......... 30% 73.9K 2m10s
6200K .......... .......... .......... .......... .......... 30% 383K 2m9s
6250K .......... .......... .......... .......... .......... 30% 764K 2m8s
6300K .......... .......... .......... .......... .......... 31% 15.6K 2m13s
6350K .......... .......... .......... .......... .......... 31% 563K 2m12s
6400K .......... .......... .......... .......... .......... 31% 509K 2m11s
6450K .......... .......... .......... .......... .......... 31% 179K 2m10s
6500K .......... .......... .......... .......... .......... 31% 141K 2m9s
6550K .......... .......... .......... .......... .......... 32% 698K 2m8s
6600K .......... .......... .......... .......... .......... 32% 136K 2m7s
6650K .......... .......... .......... .......... .......... 32% 559K 2m6s
6700K .......... .......... .......... .......... .......... 32% 36.0K 2m7s
6750K .......... .......... .......... .......... .......... 33% 42.6K 2m8s
6800K .......... .......... .......... .......... .......... 33% 140K 2m8s
6850K .......... .......... .......... .......... .......... 33% 87.9K 2m7s
6900K .......... .......... .......... .......... .......... 33% 353K 2m6s
6950K .......... .......... .......... .......... .......... 34% 824K 2m5s
7000K .......... .......... .......... .......... .......... 34% 16.1K 2m10s
7050K .......... .......... .......... .......... .......... 34% 566K 2m8s
7100K .......... .......... .......... .......... .......... 34% 149K 2m8s
7150K .......... .......... .......... .......... .......... 35% 603K 2m6s
7200K .......... .......... .......... .......... .......... 35% 246K 2m5s
7250K .......... .......... .......... .......... .......... 35% 429K 2m4s
7300K .......... .......... .......... .......... .......... 35% 832K 2m3s
7350K .......... .......... .......... .......... .......... 36% 835K 2m2s
7400K .......... .......... .......... .......... .......... 36% 152K 2m1s
7450K .......... .......... .......... .......... .......... 36% 156K 2m1s
7500K .......... .......... .......... .......... .......... 36% 122K 2m0s
7550K .......... .......... .......... .......... .......... 37% 37.6K 2m1s
7600K .......... .......... .......... .......... .......... 37% 1.20M 2m0s
7650K .......... .......... .......... .......... .......... 37% 82.5K 2m0s
7700K .......... .......... .......... .......... .......... 37% 493K 1m58s
7750K .......... .......... .......... .......... .......... 38% 514K 1m57s
7800K .......... .......... .......... .......... .......... 38% 86.5K 1m57s
7850K .......... .......... .......... .......... .......... 38% 46.9K 1m58s
7900K .......... .......... .......... .......... .......... 38% 605K 1m57s
7950K .......... .......... .......... .......... .......... 39% 49.2K 1m57s
8000K .......... .......... .......... .......... .......... 39% 31.6K 1m58s
8050K .......... .......... .......... .......... .......... 39% 145K 1m58s
8100K .......... .......... .......... .......... .......... 39% 88.3K 1m57s
8150K .......... .......... .......... .......... .......... 40% 14.9K 2m1s
8200K .......... .......... .......... .......... .......... 40% 710K 2m0s
8250K .......... .......... .......... .......... .......... 40% 666K 1m59s
8300K .......... .......... .......... .......... .......... 40% 621K 1m58s
8350K .......... .......... .......... .......... .......... 41% 185K 1m57s
8400K .......... .......... .......... .......... .......... 41% 467K 1m56s
8450K .......... .......... .......... .......... .......... 41% 31.6K 1m57s
8500K .......... .......... .......... .......... .......... 41% 175K 1m56s
8550K .......... .......... .......... .......... .......... 41% 51.1K 1m56s
8600K .......... .......... .......... .......... .......... 42% 674K 1m55s
8650K .......... .......... .......... .......... .......... 42% 335K 1m54s
8700K .......... .......... .......... .......... .......... 42% 319K 1m53s
8750K .......... .......... .......... .......... .......... 42% 599K 1m52s
8800K .......... .......... .......... .......... .......... 43% 55.0K 1m53s
8850K .......... .......... .......... .......... .......... 43% 184K 1m52s
8900K .......... .......... .......... .......... .......... 43% 163K 1m51s
8950K .......... .......... .......... .......... .......... 43% 659K 1m50s
9000K .......... .......... .......... .......... .......... 44% 89.0K 1m50s
9050K .......... .......... .......... .......... .......... 44% 486K 1m49s
9100K .......... .......... .......... .......... .......... 44% 140K 1m48s
9150K .......... .......... .......... .......... .......... 44% 694K 1m47s
9200K .......... .......... .......... .......... .......... 45% 668K 1m46s
9250K .......... .......... .......... .......... .......... 45% 673K 1m45s
9300K .......... .......... .......... .......... .......... 45% 627K 1m44s
9350K .......... .......... .......... .......... .......... 45% 60.4K 1m44s
9400K .......... .......... .......... .......... .......... 46% 71.5K 1m44s
9450K .......... .......... .......... .......... .......... 46% 119K 1m44s
9500K .......... .......... .......... .......... .......... 46% 456K 1m43s
9550K .......... .......... .......... .......... .......... 46% 164K 1m42s
9600K .......... .......... .......... .......... .......... 47% 611K 1m41s
9650K .......... .......... .......... .......... .......... 47% 90.7K 1m41s
9700K .......... .......... .......... .......... .......... 47% 68.6K 1m41s
9750K .......... .......... .......... .......... .......... 47% 54.3K 1m41s
9800K .......... .......... .......... .......... .......... 48% 63.6K 1m40s
9850K .......... .......... .......... .......... .......... 48% 51.8K 1m40s
9900K .......... .......... .......... .......... .......... 48% 948K 1m40s
9950K .......... .......... .......... .......... .......... 48% 31.3K 1m40s
10000K .......... .......... .......... .......... .......... 49% 24.9K 1m41s
10050K .......... .......... .......... .......... .......... 49% 604K 1m40s
10100K .......... .......... .......... .......... .......... 49% 508K 1m40s
10150K .......... .......... .......... .......... .......... 49% 74.9K 99s
10200K .......... .......... .......... .......... .......... 50% 465K 98s
10250K .......... .......... .......... .......... .......... 50% 377K 98s
10300K .......... .......... .......... .......... .......... 50% 499K 97s
10350K .......... .......... .......... .......... .......... 50% 560K 96s
10400K .......... .......... .......... .......... .......... 51% 89.9K 96s
10450K .......... .......... .......... .......... .......... 51% 140K 95s
10500K .......... .......... .......... .......... .......... 51% 701K 94s
10550K .......... .......... .......... .......... .......... 51% 725K 93s
10600K .......... .......... .......... .......... .......... 52% 167K 93s
10650K .......... .......... .......... .......... .......... 52% 144K 92s
10700K .......... .......... .......... .......... .......... 52% 70.7K 92s
10750K .......... .......... .......... .......... .......... 52% 515K 91s
10800K .......... .......... .......... .......... .......... 52% 576K 90s
10850K .......... .......... .......... .......... .......... 53% 173K 90s
10900K .......... .......... .......... .......... .......... 53% 73.5K 89s
10950K .......... .......... .......... .......... .......... 53% 1.03M 88s
11000K .......... .......... .......... .......... .......... 53% 538K 88s
11050K .......... .......... .......... .......... .......... 54% 118K 87s
11100K .......... .......... .......... .......... .......... 54% 673K 86s
11150K .......... .......... .......... .......... .......... 54% 602K 86s
11200K .......... .......... .......... .......... .......... 54% 87.6K 85s
11250K .......... .......... .......... .......... .......... 55% 397K 84s
11300K .......... .......... .......... .......... .......... 55% 108K 84s
11350K .......... .......... .......... .......... .......... 55% 723K 83s
11400K .......... .......... .......... .......... .......... 55% 885K 82s
11450K .......... .......... .......... .......... .......... 56% 160K 82s
11500K .......... .......... .......... .......... .......... 56% 637K 81s
11550K .......... .......... .......... .......... .......... 56% 863K 80s
11600K .......... .......... .......... .......... .......... 56% 510K 80s
11650K .......... .......... .......... .......... .......... 57% 264K 79s
11700K .......... .......... .......... .......... .......... 57% 635K 78s
11750K .......... .......... .......... .......... .......... 57% 170K 78s
11800K .......... .......... .......... .......... .......... 57% 155K 77s
11850K .......... .......... .......... .......... .......... 58% 594K 76s
11900K .......... .......... .......... .......... .......... 58% 593K 76s
11950K .......... .......... .......... .......... .......... 58% 627K 75s
12000K .......... .......... .......... .......... .......... 58% 101K 75s
12050K .......... .......... .......... .......... .......... 59% 97.4K 74s
12100K .......... .......... .......... .......... .......... 59% 168K 74s
12150K .......... .......... .......... .......... .......... 59% 524K 73s
12200K .......... .......... .......... .......... .......... 59% 169K 72s
12250K .......... .......... .......... .......... .......... 60% 140K 72s
12300K .......... .......... .......... .......... .......... 60% 562K 71s
12350K .......... .......... .......... .......... .......... 60% 573K 71s
12400K .......... .......... .......... .......... .......... 60% 525K 70s
12450K .......... .......... .......... .......... .......... 61% 28.2K 70s
12500K .......... .......... .......... .......... .......... 61% 646K 70s
12550K .......... .......... .......... .......... .......... 61% 54.3K 70s
12600K .......... .......... .......... .......... .......... 61% 179K 69s
12650K .......... .......... .......... .......... .......... 62% 69.1K 69s
12700K .......... .......... .......... .......... .......... 62% 17.7K 70s
12750K .......... .......... .......... .......... .......... 62% 62.1K 70s
12800K .......... .......... .......... .......... .......... 62% 489K 69s
12850K .......... .......... .......... .......... .......... 62% 566K 68s
12900K .......... .......... .......... .......... .......... 63% 184K 68s
12950K .......... .......... .......... .......... .......... 63% 343K 67s
13000K .......... .......... .......... .......... .......... 63% 183K 67s
13050K .......... .......... .......... .......... .......... 63% 254K 66s
13100K .......... .......... .......... .......... .......... 64% 35.1K 66s
13150K .......... .......... .......... .......... .......... 64% 328K 65s
13200K .......... .......... .......... .......... .......... 64% 26.6K 66s
13250K .......... .......... .......... .......... .......... 64% 91.9K 65s
13300K .......... .......... .......... .......... .......... 65% 781K 65s
13350K .......... .......... .......... .......... .......... 65% 1.05M 64s
13400K .......... .......... .......... .......... .......... 65% 976K 63s
13450K .......... .......... .......... .......... .......... 65% 770K 63s
13500K .......... .......... .......... .......... .......... 66% 1.45M 62s
13550K .......... .......... .......... .......... .......... 66% 714K 61s
13600K .......... .......... .......... .......... .......... 66% 473K 61s
13650K .......... .......... .......... .......... .......... 66% 178K 60s
13700K .......... .......... .......... .......... .......... 67% 141K 60s
13750K .......... .......... .......... .......... .......... 67% 52.9K 60s
13800K .......... .......... .......... .......... .......... 67% 155K 59s
13850K .......... .......... .......... .......... .......... 67% 139K 59s
13900K .......... .......... .......... .......... .......... 68% 475K 58s
13950K .......... .......... .......... .......... .......... 68% 15.4K 59s
14000K .......... .......... .......... .......... .......... 68% 427K 58s
14050K .......... .......... .......... .......... .......... 68% 602K 58s
14100K .......... .......... .......... .......... .......... 69% 61.4K 57s
14150K .......... .......... .......... .......... .......... 69% 544K 57s
14200K .......... .......... .......... .......... .......... 69% 168K 56s
14250K .......... .......... .......... .......... .......... 69% 72.9K 56s
14300K .......... .......... .......... .......... .......... 70% 513K 55s
14350K .......... .......... .......... .......... .......... 70% 599K 55s
14400K .......... .......... .......... .......... .......... 70% 566K 54s
14450K .......... .......... .......... .......... .......... 70% 70.5K 54s
14500K .......... .......... .......... .......... .......... 71% 2.65M 53s
14550K .......... .......... .......... .......... .......... 71% 141K 53s
14600K .......... .......... .......... .......... .......... 71% 71.8K 52s
14650K .......... .......... .......... .......... .......... 71% 350K 52s
14700K .......... .......... .......... .......... .......... 72% 638K 51s
14750K .......... .......... .......... .......... .......... 72% 447K 50s
14800K .......... .......... .......... .......... .......... 72% 139K 50s
14850K .......... .......... .......... .......... .......... 72% 718K 49s
14900K .......... .......... .......... .......... .......... 72% 588K 49s
14950K .......... .......... .......... .......... .......... 73% 66.1K 49s
15000K .......... .......... .......... .......... .......... 73% 621K 48s
15050K .......... .......... .......... .......... .......... 73% 69.1K 48s
15100K .......... .......... .......... .......... .......... 73% 716K 47s
15150K .......... .......... .......... .......... .......... 74% 136K 47s
15200K .......... .......... .......... .......... .......... 74% 37.1K 46s
15250K .......... .......... .......... .......... .......... 74% 546K 46s
15300K .......... .......... .......... .......... .......... 74% 169K 45s
15350K .......... .......... .......... .......... .......... 75% 112K 45s
15400K .......... .......... .......... .......... .......... 75% 129K 44s
15450K .......... .......... .......... .......... .......... 75% 689K 44s
15500K .......... .......... .......... .......... .......... 75% 147K 43s
15550K .......... .......... .......... .......... .......... 76% 57.7K 43s
15600K .......... .......... .......... .......... .......... 76% 68.2K 43s
15650K .......... .......... .......... .......... .......... 76% 15.5K 43s
15700K .......... .......... .......... .......... .......... 76% 469K 43s
15750K .......... .......... .......... .......... .......... 77% 356K 42s
15800K .......... .......... .......... .......... .......... 77% 65.9K 42s
15850K .......... .......... .......... .......... .......... 77% 660K 41s
15900K .......... .......... .......... .......... .......... 77% 869K 41s
15950K .......... .......... .......... .......... .......... 78% 937K 40s
16000K .......... .......... .......... .......... .......... 78% 489K 40s
16050K .......... .......... .......... .......... .......... 78% 552K 39s
16100K .......... .......... .......... .......... .......... 78% 67.5K 39s
16150K .......... .......... .......... .......... .......... 79% 886K 38s
16200K .......... .......... .......... .......... .......... 79% 179K 38s
16250K .......... .......... .......... .......... .......... 79% 32.4K 37s
16300K .......... .......... .......... .......... .......... 79% 610K 37s
16350K .......... .......... .......... .......... .......... 80% 142K 36s
16400K .......... .......... .......... .......... .......... 80% 172K 36s
16450K .......... .......... .......... .......... .......... 80% 90.7K 35s
16500K .......... .......... .......... .......... .......... 80% 348K 35s
16550K .......... .......... .......... .......... .......... 81% 174K 34s
16600K .......... .......... .......... .......... .......... 81% 768K 34s
16650K .......... .......... .......... .......... .......... 81% 100K 34s
16700K .......... .......... .......... .......... .......... 81% 182K 33s
16750K .......... .......... .......... .......... .......... 82% 821K 33s
16800K .......... .......... .......... .......... .......... 82% 499K 32s
16850K .......... .......... .......... .......... .......... 82% 169K 32s
16900K .......... .......... .......... .......... .......... 82% 171K 31s
16950K .......... .......... .......... .......... .......... 83% 66.7K 31s
17000K .......... .......... .......... .......... .......... 83% 51.0K 30s
17050K .......... .......... .......... .......... .......... 83% 572K 30s
17100K .......... .......... .......... .......... .......... 83% 376K 29s
17150K .......... .......... .......... .......... .......... 83% 753K 29s
17200K .......... .......... .......... .......... .......... 84% 374K 28s
17250K .......... .......... .......... .......... .......... 84% 7.46K 29s
17300K .......... .......... .......... .......... .......... 84% 541K 29s
17350K .......... .......... .......... .......... .......... 84% 183K 28s
17400K .......... .......... .......... .......... .......... 85% 160K 28s
17450K .......... .......... .......... .......... .......... 85% 527K 27s
17500K .......... .......... .......... .......... .......... 85% 592K 27s
17550K .......... .......... .......... .......... .......... 85% 310K 26s
17600K .......... .......... .......... .......... .......... 86% 374K 26s
17650K .......... .......... .......... .......... .......... 86% 173K 25s
17700K .......... .......... .......... .......... .......... 86% 727K 25s
17750K .......... .......... .......... .......... .......... 86% 311K 24s
17800K .......... .......... .......... .......... .......... 87% 651K 24s
17850K .......... .......... .......... .......... .......... 87% 614K 23s
17900K .......... .......... .......... .......... .......... 87% 101K 23s
17950K .......... .......... .......... .......... .......... 87% 379K 22s
18000K .......... .......... .......... .......... .......... 88% 682K 22s
18050K .......... .......... .......... .......... .......... 88% 64.6K 21s
18100K .......... .......... .......... .......... .......... 88% 88.1K 21s
18150K .......... .......... .......... .......... .......... 88% 478K 20s
18200K .......... .......... .......... .......... .......... 89% 175K 20s
18250K .......... .......... .......... .......... .......... 89% 573K 19s
18300K .......... .......... .......... .......... .......... 89% 143K 19s
18350K .......... .......... .......... .......... .......... 89% 525K 18s
18400K .......... .......... .......... .......... .......... 90% 56.6K 18s
18450K .......... .......... .......... .......... .......... 90% 162K 18s
18500K .......... .......... .......... .......... .......... 90% 249K 17s
18550K .......... .......... .......... .......... .......... 90% 69.9K 17s
18600K .......... .......... .......... .......... .......... 91% 518K 16s
18650K .......... .......... .......... .......... .......... 91% 121K 16s
18700K .......... .......... .......... .......... .......... 91% 586K 15s
18750K .......... .......... .......... .......... .......... 91% 512K 15s
18800K .......... .......... .......... .......... .......... 92% 515K 14s
18850K .......... .......... .......... .......... .......... 92% 103K 14s
18900K .......... .......... .......... .......... .......... 92% 540K 13s
18950K .......... .......... .......... .......... .......... 92% 99.5K 13s
19000K .......... .......... .......... .......... .......... 93% 365K 13s
19050K .......... .......... .......... .......... .......... 93% 75.1K 12s
19100K .......... .......... .......... .......... .......... 93% 185K 12s
19150K .......... .......... .......... .......... .......... 93% 71.0K 11s
19200K .......... .......... .......... .......... .......... 93% 4.07K 12s
19250K .......... .......... .......... .......... .......... 94% 56.2K 11s
19300K .......... .......... .......... .......... .......... 94% 336K 11s
19350K .......... .......... .......... .......... .......... 94% 558K 10s
19400K .......... .......... .......... .......... .......... 94% 514K 10s
19450K .......... .......... .......... .......... .......... 95% 448K 9s
19500K .......... .......... .......... .......... .......... 95% 66.9K 9s
19550K .......... .......... .......... .......... .......... 95% 68.0K 8s
19600K .......... .......... .......... .......... .......... 95% 983K 8s
19650K .......... .......... .......... .......... .......... 96% 625K 7s
19700K .......... .......... .......... .......... .......... 96% 89.2K 7s
19750K .......... .......... .......... .......... .......... 96% 563K 6s
19800K .......... .......... .......... .......... .......... 96% 536K 6s
19850K .......... .......... .......... .......... .......... 97% 36.9K 5s
19900K .......... .......... .......... .......... .......... 97% 527K 5s
19950K .......... .......... .......... .......... .......... 97% 168K 4s
20000K .......... .......... .......... .......... .......... 97% 372K 4s
20050K .......... .......... .......... .......... .......... 98% 53.2K 4s
20100K .......... .......... .......... .......... .......... 98% 172K 3s
20150K .......... .......... .......... .......... .......... 98% 169K 3s
20200K .......... .......... .......... .......... .......... 98% 300K 2s
20250K .......... .......... .......... .......... .......... 99% 664K 2s
20300K .......... .......... .......... .......... .......... 99% 348K 1s
20350K .......... .......... .......... .......... .......... 99% 108K 1s
20400K .......... .......... .......... .......... .......... 99% 553K 0s
20450K .......... .......... .......... 100% 20.3K=3m10s
2016-12-26 14:39:59 (108 KB/s) - '20MB.zip' saved [20971520/20971520]
davenos
Re: Odd TBB test ?
The support staff are still insisting that the x1 test error is a Windows 10/ flash error and is not effecting other OS's, this is despite the evidence in this thread showing it effects different OS's, HTML5 tests and physical downloads.
Im frankly now well past fed up with the customer service and the constant lies/contradictory information or down right denial of any issues.
My complaint to Plusnet outlining the issues has seen them focus solely on the peak time slowdowns and ignore the other parts(packet loss and this latest x1 issue)they only want to address the slowdowns via an engineer visit even though their tests tell them one is not needed.
SteveA
Re: Odd TBB test ?
So has anyone pointed someone from PN to the non Win 10 / Flash results in this thread. My wife is basically getting sick and fed up of things not working properly. Suggests the current PN TV adverts should be reported as misleading and deceptive.
MrSilver
Fixes: 9
Re: Odd TBB test ?
i know people seem sick of testing stuff, so far form all my tests on linux iso's, game downloads, dropbox etc. I cant get the 1x mega slowdown problem on anything other than some gateways and the 20mb speedtest.
Others get different gateways and 1 report of BF1 being slow.
I know there is a general peak time slowdown problem too, but on the specific single thread going  slow i've yet to see anything reproducible on another site ?
My line is running at 40meg instead of 78 so i hope they fix that as that seems to break everything, but so far all this seems to have proven to be effecting is the single thread speedtest....
MrSilver
Fixes: 9
Re: Odd TBB test ?
@rongtw wrote:
@MrSilver  Its full game download from EA , BF1  it was on offer 50% discount
btw - thanks for this as I wanted BF1 and now got 50% off too 😉
