Is it time to move on?
- Is it time to move on?
Re: Is it time to move on?
09-05-2019 11:00 AM
09-05-2019 1:51 PM
Sorry to hear you're still having issues @SUPRAASH
If you're still having issues after you've received the new router let us know
09-05-2019 8:27 PM - edited 09-05-2019 8:28 PM
I've mentioned this to plusnet in the past but never seem to get anywhere with them fixing the issue. I believe it's the line
If that's the case I'll never get my issue resolved
09-05-2019 8:31 PM
I see 2 really thin ones but also see wires in there that are not connected
09-05-2019 9:23 PM
@SUPRAASH wrote:
Something is not right anytime I stream I get lagging and it stopping.
Is the router rebooting though?
How many wires go into the front of my box on the wall?
2 wires go to terminals A&B. the other wires are not needed. It does sound like you may have other phone extensions and these could be the other wires you're seeing.
09-05-2019 11:01 PM
09-05-2019 11:26 PM
How are you connecting to the hub 6?
(over wifi or ethernet)
I've asked already, but is the hub 6 also rebooting?
If it's rebooting then Plusnet might pop up the results of a RADIUS graph (and a GEA test)
If it isn't rebooting, then unless the GEA test flags anything, I'm not sure what they could suggest next.
09-05-2019 11:30 PM
Or dropping internet.
I have reset the bt hub6 and signed in to the plusnet username. I'm connected to wireless with my TV and firestick also mobile phones.
The xbox are wired
09-05-2019 11:43 PM
It not rebooting is a good thing, though buffering issues (if wired) is a problem, as is the device losing the internet.
Are all devices having issues or is it one device in particular?
10-05-2019 12:02 AM
10-05-2019 12:31 AM
It's not a Samsung TV is it?
10-05-2019 10:47 AM
Hi SUPRAASH, I've just been running some diagnostic checks and we're not seeing any obvious issues or faults relating to the line. Do you get the same lag or buffering when all other devices are disconnected?
10-05-2019 4:58 PM
10-05-2019 4:59 PM
10-05-2019 5:01 PM
