Internet keeps dropping
- Re: Internet keeps dropping
07-03-2018 2:34 PM
Hi not sure what the issue could be but my internet connection often drops connection during day/night. I'm connected via Ethernet cable and using TG582n router. Can you see any issues your end?
Thanks Val
07-03-2018 2:44 PM
My event report.
07-03-2018 2:52 PM
Hi Val. Sorry to hear you're having connection problems.
The connection between your router and the phone line seems stable:
Do you experience drops using more than one device?
Also, would you be able to connect your PC directly into the Openreach modem setting up a PPPoE connection as explained here? This would determine if your router is at fault.
07-03-2018 2:55 PM
I do have similar problems on my daughters PC too, I will check the other things you suggest and report back, thanks.
11-03-2018 11:14 PM
Is that a throw-a-way hint that this is a fibre service not ADSL?
Can TG582n routers be suitably configured in bridge mode?
12-03-2018 9:08 PM
Aye.
Pretty sure it can be, though it's not something I'd know how to do.
12-03-2018 10:43 PM
Moderator's note by Mike (Mav): This thread is now in the appropriate board.
Forum Moderator and Customer
