Internet keeps dropping
Val3
Hi not sure what the issue could be but my internet connection often drops connection during day/night. I'm connected via Ethernet cable and using TG582n router. Can you see any issues your end?
Thanks Val
6 REPLIES 6
Val3
Re: Internet keeps dropping
Fixes: 1,600
Hi Val. Sorry to hear you're having connection problems.
The connection between your router and the phone line seems stable:
Do you experience drops using more than one device?
Also, would you be able to connect your PC directly into the Openreach modem setting up a PPPoE connection as explained here? This would determine if your router is at fault.
Val3
I do have similar problems on my daughters PC too, I will check the other things you suggest and report back, thanks.
Fixes: 160
Is that a throw-a-way hint that this is a fibre service not ADSL?
Can TG582n routers be suitably configured in bridge mode?
Anoush
Aspiring Hero
Fixes: 139
Aye.
Pretty sure it can be, though it's not something I'd know how to do.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Mav
Fixes: 515
Moderator's note by Mike (Mav): This thread is now in the appropriate board.
Forum Moderator and Customer
