BTw Performance Test via Further Diagnostics
- Re: BTw Performance Test via Further Diagnostics
19-02-2015 11:59 AM
1. Best Effort Test: -provides background information.
Download Speed
37.91 Mbps
0 Mbps 72.21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 37.91 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-72.21 Mbps .
Additional Information:
IP Profile for your line is - 72.21 Mbps
Upload Speed
16.78 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 16.78Mbps
PN Current Line Speed: 40 Mb
19-02-2015 12:29 PM
Plusnet provision everyone on the same 80/20 product with their suppliers, but will apply a downstream limit of 40Mbps their end for those on the fibre unlimited package.
19-02-2015 4:56 PM
https://windows.mouselike.org/be/index.asp?DoAction=BrasChecker
19-02-2015 7:06 PM
Looks like BT refused to test, possibly because a speed test or BRAS check has been run recently which prevents this tool from working. Try again in a few hours.
Debug: BT no BRAS info
20-02-2015 9:50 AM
20-02-2015 10:00 AM
20-02-2015 2:34 PM
I always get the same message:
Quote Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
20-02-2015 4:37 PM
By the way not once have I had that error message, if that helps in the slightest, just ran one using our work's connection and it worked fine too
20-02-2015 4:46 PM
21-02-2015 2:18 PM
Download Speed : 19.65 Mbps
2. Upstream Test:
Upload Speed : 15.32 Mbps
21-02-2015 2:20 PM
21-02-2015 2:24 PM
FAQ
Results Image not loaded
Download Speed : 37.28 Mbps
2. Upstream Test:
Upload Speed : 15.58 Mbps
23-02-2015 9:02 AM
@vindaloojim
@dean197gmail
I've checked both your circuits this morning and forwarded your details including the screenshots to our supplier for further investigation.
Once I have more information, I will update this post further.
24-02-2015 2:11 AM
Kind regards
Mr Dean Mason
24-02-2015 8:08 AM
