asus DSL-AC68U help please
seadragon18
Hi
Just got a DSL-AC68U to use with my plusnet.
having problems setting it up..
update to latest Firmware 3.0.0.4.376_2072
run the Quick internet setup, but it doesn't connect to the internet
I have attached WAN setting
Any help would be great
Fixes: 162
Re: asus DSL-AC68U help please
I'm sure that someone else will be able to check the rest of the settings for you, but are you putting the username in with @plusdsl.net on the end?
 Chris Parr
 Plusnet Staff
As Chirs says, your user name doesn't seem long enough?
seadragon18
Thanks very much Chris & tijara33
What a stupid mistake to make.. wastied hours on web searching what went wrong..
Up & running now...
Fixes: 162
You're not alone! It's something that has been missed by people over the years so I wouldn't worry about it. Glad to hear you're up and running now.
 Chris Parr
 Plusnet Staff
I was writing from bitter experience!! Roll eyes Glad it's sorted.
Cecemf
Just installed that dsl/router love it I must say the WIFI is AMAZING ! had loads of issue with wifi signal in the past but now full bars everywhere.
HaydnExport
Dont get too exited  , my speedtest was almost identical to yours when i first had the asus , now i get this
im now back to the openreach modem and using the asus as router only.
Check the overclockers forum for a 56 page thread of random disconnects worst modem in history with bt's dlm.
