Usenet not working
Lwio
Re: Usenet not working
Just to add usenet on newshostings Mac app is working. Using hub 2 and high sierra on an 09 Mac Pro on fttp.
You can get older versions of the newshosting app depending on your os.
Stoker
Anyone finding their connection times out after 5 minutes or so of inactivity? I've not changed anything in my usenet client (Thunderbird) for years, though of course it does update itself occasionally. I can't see any timeout options in the server / connection settings.
iw6dgm
Just tried and I can confirm the issue (Thunderbird 102.6.1 64-bit).
Sounds more likely a bug introduced by one of the latest versions of Thunderbird
iw6dgm
After many Thunderbird's updates the timeouts persist, I am now more inclined to believe this is an issue with the newsservers
Stoker
Just realised I mentioned the timeout problem in this thread but put the solution in another one.
In Thunderbird right-click usenet.plus.net, then in "server settings", tick "check for new messages every ..." and choose 5 minutes.
I've found this keeps the connection alive indefinitely.
