Landline Switch off 2025
MAREK_W
Dear Plusnet,
Just to ask about the nationwide landline switch-off, taking place at the end of 2025.  As it says, landlines will not be in use anymore, the telephone network will then be 'in the cloud'.  I understand that routers, in order to deliver broadband as they always have done, will then need to have a phone 'socket' in order to connect to broadband.  Has Plusnet changed its routers to accept this?
Yours
Marek
3 REPLIES 3
Fixes: 387
Re: Landline Switch off 2025
As it stands with Plusnet at the moment, the Hubs supplied do not have VoIP capabilities, and they do not currently offer such a service to those moving to FTTP - you have to arrange your own VoIP service, should you require one. NOTE - this does not say what they will be doing in the future.
Fixes: 585
not necessarily. They only need a phone socket to connect an existing analogue style phone to a voip service.
Not everyone wants a voip service. There are also other ways of connecting to a voip service.
A separate analogue telephone adapter(,ATA)  which connects to the phone and then to the router using ethernet.
A separate dedicated voip phone which just connects directly to the router via ethernet.
A wireless voip phone.
Mav
Fixes: 518
Moderator's note(s):
Thread moved from Broadband to Everything Else.
Forum Moderator and Customer
