Safeguard won't stay enabled
FIXED- Subscribe to RSS Feed
- Everything else
- Re: Safeguard won't stay enabled
27-11-2020 5:11 PM
There was a bit of dodgy data associated with your accounts which was stopping it from working. We've now got a fix for when it's reported to us, and I'm looking at a wider clean up to make sure any other people aren't affected in future.
Ex-Plusnet Jobsbody
28-11-2020 12:05 PM
- WELL DONE KELLY! Seems sorted now, thanks.
28-11-2020 11:34 PM
Hi Kelly, could you please also apply the fix on my account? I’ve had the same problem with SafeGuard not switching on. It seemed to start when I upgraded my fibre speed a few months ago, but that could just be a coincidence.
Thanks very much,
01-12-2020 8:41 AM
@graham_s PM over your username and I'll get it raised! When did you upgrade to fibre, out of interest?
Ex-Plusnet Jobsbody
01-12-2020 9:13 PM
02-12-2020 4:20 AM
03-12-2020 8:53 AM
@lynncarson Hi! PM over your username and I'll have a look for you
Ex-Plusnet Jobsbody
03-12-2020 8:54 AM
@bitzy007 I presume you've tried to turn it on but it's turned itself off? Can you check if it's still enabled? If it's seems to be turning itself off, then I need your username and I'll have a look.
Ex-Plusnet Jobsbody
03-12-2020 12:18 PM
03-12-2020 12:51 PM
@Simers1983 PM me over a bit more detail and I'll get someone to take a look.
Ex-Plusnet Jobsbody
03-12-2020 8:41 PM
04-12-2020 2:55 PM
@bitzy007 Hi, I've checked and it appears to be enabled properly. Can you call up the call centre and discuss with one of our team? They'll a bit more info to work out what's happening here.
Ex-Plusnet Jobsbody
04-12-2020 3:12 PM
You are both affected. I've raised an action to fix this for you. Hopefully done early next week!
Ex-Plusnet Jobsbody
05-12-2020 7:23 AM
06-12-2020 5:37 PM
I have the same problem.
Trying on the safegaurd , however later it turn off automatically. Not blocking any site at all, rally worrying about the kids.
- Everything else
