Gateway Checker Update
spraxyt
Resting Legend
Fixes: 75
Re: Gateway Checker Update
Thanks, that final hop should be pcl-bng02. Still awaiting Plusnet updating its DNS entry.
David
David
Araf
Which gateway
Sorry, the tool failed to identify your gateway; this does not mean that anything is wrong with your connection.
Posting the following information as a reply to the Gateway Checker Update topic in the Community Announcements forum will help us to diagnose the problem.
ae2.ptw-cr02.plus.net (195.166.129.5) 3.259 ms
SpendLessTime
Fixes: 86
peer6-te0-0-0-10.telehouse.ukcore.bt.net (109.159.254.104) 4.796 ms
195.99.126.183 (195.99.126.183) 6.033 ms
Okay I guess this is down to the DSN/Networking issues that have been ongoing since just after midnight. So not a real issue.
spraxyt
Resting Legend
Fixes: 75
Quote from: georgelnx
Yes, I think you are right. Until things return to normal please ignore any errors from the gateway checker.
David
David
spraxyt
Resting Legend
Fixes: 75
The gateway checker seems to be working OK again now the network and/or DNS issues have been fixed.
David
David
lenny
Gateway checker gives me this
Which gateway
peer6-te0-9-0-15.telehouse.ukcore.bt.net (109.159.252.59) 3.502 ms
195.99.126.183 (195.99.126.183) 6.715 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 3.669 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 3.635 ms
Mayfly
All Star
Ditto^^^^^^^
acc2-10GigE-0-3-0-2.l-far.21cn-ipp.bt.net (109.159.249.172) 3.800 ms
195.99.126.99 (195.99.126.99) 2.503 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 3.333 ms
spraxyt
Resting Legend
Fixes: 75
Thanks. A month has now passed since these IPs were flagged up for attention. I guess it's a low priority task.
David
David
jelv
Fixes: 10
Why on earth after all these years they still haven't got setting up the DNS entries as part of the tick list when new end points are set up is beyond me!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Mayfly
All Star
I've just lost connection and the troubleshooter tells me it was a gateway problem when checking again I got this
acc2-10GigE-0-3-0-2.l-far.21cn-ipp.bt.net (109.159.249.172) 4.702 ms
195.99.126.99 (195.99.126.99) 3.444 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 4.145 ms
No idea if it's related tho' as I don't understand such things.
spraxyt
Resting Legend
Fixes: 75
I think the gateway that refers to is probably your router rather than the handover point to Plusnet. The latter, which the checker refers to a your gateway was unchanged after the incident.
David
David
bluesky
Just got this from the gateway checker,
Which gateway
ae2.ptw-cr02.plus.net (195.166.129.5) 35.634 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 3.247 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 3.111 ms
Thanks.
spraxyt
Resting Legend
Fixes: 75
Thanks, the problem has been reported.
David
David
lewer10
peer6-Te0-0-0-21.telehouse.ukcore.bt.net (109.159.254.46) 3.878 ms
195.99.126.183 (195.99.126.183) 3.868 ms
link3-central10.pcl-gw01.plus.net (84.93.249.196) 3.863 ms
spraxyt
Resting Legend
Fixes: 75
Thanks, problem noted.
David
David
